Inside folder has a .plexmatch: Title: The Stranger Year: 2020 tvdbid: 374977 imdbid: tt9698480
With a single directory Season 1 with all episodes within.
Folder name: The Stranger (2020) (US) {tvdb-376911}
Inside folder has .plexmatch: Title: The Stranger (2020) (US) Year: 2020 tvdbid: 376911 imdbid: tt10681780
Only the first show is identified and shows up in Plex. The other one is ignored entirely. Here is both shows in Plex Search:
Thanks yeah it has access there already. It sees all the other TV shows, just not this one. I suspect due to 2 shows having the same name and year, but I provided it with both imdb and tvdb ID’s to no prevail.
It could be that they are matched as one show. For the show that you do see can you select the show to view the show’s detail page. From there select the ... context menu and see if you see a Split Apart option
Switched to tmdb in folder titles (and .plexmatch) but no luck. I also tried commenting out the tvdb & imdb id’s in the .plexmatch (so it only has tmdb: 99282 but no luck.
