Plex Media Player Remove duplicate folder and Empty Recycle Bin
plex-media-player
#1
I am using Plex Media Player and I would like to empty my Recycle bin.
It seems to be full with some empty folder. This is only from Media Player Folder View; the storage is ok.
I have noticed also a lot of empty folder named "Folder Name - Copy (n)" and I would like to delete them too.
Anyone can help me to address this issue?
Thanks,
Giorgio
#2
Could you please provide some screenshots?
I have a hard time to understand what you are experiencing.
#3
yes of course
/uploads/default/original/3X/5/5/5572f337f2f4347443790d2c36650d872b333c4e.jpg
Thank you!!!
#4
You are using the ‘folder view’.
Plex is not a file manager.
Use the file manager of your operating system or your NAS to get rid of those folders.
#5
Hi Otto thank you for your reply,
I think that this is a Render Bug of the Folder View. In the File System of my NAS everything is OK.
In the Folder View I saw those Folders and quite the same in the browsing the recycle bin.
I cannot delete them for 2 reason:
  1. there is nothing to delete (they seem to be ghost folders)
  2. no button is provided in the Plex Media Player for those kind of empty folders (for other content I can delete the files from the Media Player)
I would like just to remove them from my Folder View.
Regards,
Giorgio
#6
These folders must at least have been there, when the library was updated once.
Simply update the library again (‘Scan library Files’)
https://support.plex.tv/articles/200392106-library-actions/
Once that is finished, empty the library trash.
If that still doesn’t work, Edit your library
go to the ‘Add Folders’ tab and verify that all folder paths referenced there,
  • are still in existence
  • folders are not completely empty
  • each folder is accessible to Plex Server (which is not as easily done as said, because on some NAS platforms, Plex runs under a different user account [plex], so you must learn about Linux permissions )
#7
Thanks Otto, you got the point.
After scanned the library again and emptied the trash all the ghost folder are gone away.
thanks again.
G.
