Server Version#:1.19.3.2843
Player Version#:1.8.21192
The more I change settings, the more problems I have. I have uninstalled and reinstalled and now flex cannot locate the Plex Media Server. Please help.
log file: May 23, 2020 18:03:29.070 [10636] INFO - Plex Media Server v1.19.3.2843-e3c1f7bcd - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
May 23, 2020 18:03:29.070 [10636] INFO - Windows version: 10.0 (Build 18363), language en-US
May 23, 2020 18:03:29.070 [10636] INFO - 4 1833 MHz processor(s): Architecture=0, Level=6, Revision=14088 Processor Identifier=Intel64 Family 6 Model 55 Stepping 8, GenuineIntel
May 23, 2020 18:03:29.070 [10636] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe”
May 23, 2020 18:03:29.265 [10612] DEBUG - Plex for Windows Store application is not installed
May 23, 2020 18:03:29.270 [10612] DEBUG - BPQ: [Idle] -> [Starting]
May 23, 2020 18:03:29.277 [10612] DEBUG - FeatureManager: Using cached data for features list
May 23, 2020 18:03:29.278 [10612] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
May 23, 2020 18:03:29.568 [10612] DEBUG - Running migrations. (EPG 0)
May 23, 2020 18:03:29.571 [10612] DEBUG - ChangestampAllocator: initialized to 0
May 23, 2020 18:03:29.572 [10612] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
May 23, 2020 18:03:29.617 [10612] DEBUG - Running migrations. (EPG 0)
May 23, 2020 18:03:29.756 [10612] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
May 23, 2020 18:03:29.756 [10612] DEBUG - HttpServer: Listening on port 32400.
May 23, 2020 18:03:29.769 [10612] DEBUG - HttpServer: Listening on port 32401.
May 23, 2020 18:03:30.092 [10612] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
May 23, 2020 18:03:30.092 [10612] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
May 23, 2020 18:03:30.093 [10612] DEBUG - Relay: read 0 cached entries from hosts file
May 23, 2020 18:03:30.094 [10612] DEBUG - Opening 1 database sessions to library (), SQLite 3.26.0, threadsafe=1
May 23, 2020 18:03:30.104 [10664] DEBUG - Grabber: Cleaning up orphaned grabs.
May 23, 2020 18:03:30.106 [10664] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
May 23, 2020 18:03:30.107 [10664] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=
May 23, 2020 18:03:30.113 [10748] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
May 23, 2020 18:03:30.119 [10756] DEBUG - File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-e3c1f7bcd” changed: -1 => 2020-05-23 18:00:57 (1590271257).
May 23, 2020 18:03:30.120 [10756] DEBUG - File “C:\Users\witti\AppData\Local\Plex Media Server\Plug-ins” changed: -1 => 2020-05-23 16:29:39 (1590265779).
May 23, 2020 18:03:30.120 [10756] DEBUG - Scanning for plug-ins in “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-e3c1f7bcd”
May 23, 2020 18:03:30.175 [10756] DEBUG - Scanning for plug-ins in “C:\Users\witti\AppData\Local\Plex Media Server\Plug-ins”
May 23, 2020 18:03:30.176 [10756] DEBUG - PluginRepository::setStartState: 1, startingSystem
May 23, 2020 18:03:30.176 [10756] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-e3c1f7bcd\System.bundle.
May 23, 2020 18:03:30.177 [10756] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
May 23, 2020 18:03:30.189 [10756] DEBUG - Starting file watcher for com.plexapp.system
May 23, 2020 18:03:30.192 [10756] DEBUG - Plugin: not setting user token for plugin
May 23, 2020 18:03:30.193 [10756] DEBUG - Plugin::createProcess: Creating plugin process: “C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-e3c1f7bcd\Framework.bundle\Contents\Resources\Versions\2\Python\bootstrap.py” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-e3c1f7bcd\System.bundle”
May 23, 2020 18:03:30.203 [10756] DEBUG - Spawned plug-in com.plexapp.system with PID 10792
May 23, 2020 18:03:30.203 [10756] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
May 23, 2020 18:03:30.798 [10664] DEBUG - HTTP 401 response from GET https://plex.tv/media/providers?X-Plex-Token=
May 23, 2020 18:03:31.292 [10752] DEBUG - Job running: C:\Program Files (x86)\Plex\Plex Media Server\CrashUploader.exe “–directory=C:\Users\witti\AppData\Local\Plex Media Server\Crash Reports\1.19.3.2843-e3c1f7bcd” --version=1.19.3.2843-e3c1f7bcd --platform=Windows “–platformVersion=10.0 (Build 18363)” --serverUuid=5f767564be443dbd8346708ceae767150fec0629 --userId=NOUSERID --sentryUrl=https://sentry.io/api/1233455/minidump --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=Microsoft --model=x64 --device=PC
May 23, 2020 18:03:31.303 [10752] DEBUG - Jobs: Starting child process with pid 10816
May 23, 2020 18:03:40.246 [10752] DEBUG - DVR:Device: Discovering and refreshing all devices.
May 23, 2020 18:03:40.247 [10752] DEBUG - Creating NetworkServices singleton.
May 23, 2020 18:03:40.301 [10752] DEBUG - NetworkService: Creating new service.
May 23, 2020 18:03:40.301 [10752] DEBUG - NetworkService: Got notification of changed network (first change: 1)
May 23, 2020 18:03:40.301 [10752] DEBUG - NetworkService: Quick dispatch of network change.
May 23, 2020 18:03:40.301 [10752] DEBUG - Grabber: HDHomerun discovered 0 compatible devices.
May 23, 2020 18:03:40.303 [10752] DEBUG - HTTP requesting POST http://127.0.0.1:32600/devices/discover
May 23, 2020 18:03:40.356 [11600] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
May 23, 2020 18:03:40.356 [11600] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:1901
May 23, 2020 18:03:44.580 [10752] ERROR - Error issuing curl_easy_perform(handle): 7
May 23, 2020 18:03:44.580 [10752] WARN - HTTP error requesting POST http://127.0.0.1:32600/devices/discover (7, Couldn’t connect to server) (Failed to connect to 127.0.0.1 port 32600: Connection refused)
May 23, 2020 18:03:44.581 [10752] DEBUG - Grabber: Failed to retrieve device data
May 23, 2020 18:03:49.918 [3592] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\CrashUploader.exe’ exit code for process 10816 is 0 (success)
May 23, 2020 18:04:26.717 [10756] DEBUG - Reading 486 bytes in the body, code is 200
May 23, 2020 18:04:26.717 [10756] DEBUG - [com.plexapp.system] Plug-in running on port 50127.
May 23, 2020 18:04:26.717 [10756] DEBUG - * Plug-in handles prefix: /system
May 23, 2020 18:04:26.717 [10756] DEBUG - * Plug-in handles prefix: /player
May 23, 2020 18:04:26.717 [10756] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
May 23, 2020 18:04:26.722 [10756] DEBUG - Updating [com.plexapp.system] in the database, it has changed.
May 23, 2020 18:04:26.724 [10756] DEBUG - Done with 1 synchronous plug-in starts, starting the rest in parallel.
May 23, 2020 18:04:26.724 [10756] DEBUG - PluginRepository::setStartState: 2, startingPlugins
May 23, 2020 18:04:26.724 [10756] DEBUG - Updating the list of agents known by the system.
May 23, 2020 18:04:26.724 [10756] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
May 23, 2020 18:04:26.725 [10756] DEBUG - HTTP requesting GET http://127.0.0.1:50127/system/agents
May 23, 2020 18:04:26.725 [10612] DEBUG - Image transcode cache directory: “C:\Users\witti\AppData\Local\Plex Media Server\Cache\PhotoTranscoder”
May 23, 2020 18:04:26.726 [10612] DEBUG - Transcoder: Cleaning old transcode directories.
May 23, 2020 18:04:26.730 [10612] ERROR - Transcoder: Error cleaning old transcode sessions: boost::filesystem::directory_iterator::construct: The system cannot find the path specified: “C:\Users\witti\AppData\Local\Plex Media Server\Cache\Transcode\Sessions”
May 23, 2020 18:04:26.731 [10612] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 23, 2020 18:04:26.813 [10612] DEBUG - NetworkInterface: ignoring adapter ‘Ethernet’ (fe80::448a:d452:6bf7:4399%20,169.254.67.153) because it has no gateway
May 23, 2020 18:04:26.813 [10612] DEBUG - NetworkInterface: ignoring adapter ‘Local Area Connection* 6’ (fe80::49e4:1553:5d39:2029%22,169.254.32.41) because it has no gateway
May 23, 2020 18:04:26.813 [10612] DEBUG - NetworkInterface: ignoring adapter ‘Ethernet 2’ (fe80::a141:25c:c66e:b0cb%4,169.254.176.203) because it has no gateway
May 23, 2020 18:04:26.869 [10612] DEBUG - NetworkInterface: ignoring adapter ‘Loopback Pseudo-Interface 1’ (::1,127.0.0.1) because it has no gateway
May 23, 2020 18:04:26.870 [10612] DEBUG - Detected primary interface: 192.168.200.50
May 23, 2020 18:04:26.870 [10612] DEBUG - Network interfaces:
May 23, 2020 18:04:26.870 [10612] DEBUG - * 10 Wi-Fi {438A654D-EB2D-4571-9828-335AD6E19BEE} (192.168.200.50) (loopback: 0)
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkService: Got notification of changed network (first change: 0)
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkService: Dispatch network change after two second delay.
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkServices: Initializing…
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkService: Creating new service.
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkService: Got notification of changed network (first change: 1)
May 23, 2020 18:04:26.870 [10612] DEBUG - NetworkService: Quick dispatch of network change.
May 23, 2020 18:04:26.871 [10612] DEBUG - NetworkService: Creating new service.
May 23, 2020 18:04:26.871 [10612] DEBUG - NetworkService: Got notification of changed network (first change: 1)
May 23, 2020 18:04:26.871 [10612] DEBUG - NetworkService: Quick dispatch of network change.
Hopefully this is enough information as the entire log was too big.
