Hello guys has anybody had issues with Plex on Nvidia Shield (used only to stream from Unraid) i am finding primarily on TV Shows but films as well struggling to resume. I must either reboot or go into season and find the episode try from there but that does not always work! So not sure if it is Unraid Plex or Andriod Plex been doing it for 3 weeks.
is this after backing out to the item in list after stopping without going elsewhere? I believe there is an issue with the poster/thumb not always updating ( with the bar that represents position) so when you hit play again it starts from the beginning. When it happens often need to leave page and come back to it to force it to update the poster/thumb with new watch state
Actually if i stop for a break then start it is ok. If i stop partially way through and come back the day after. If i hit resume from the continue watching area it just spins. I have even rebooted several times it will not play. If go directly to TV press on thumbnail to resume it will not if i hit resume button ut works 80% of the time. But it is intermittent but getting worse
