Hy.
I searched the forum about this topic but I did not find anything specific like this.
So I just built a Plex Media Server.
The config is the following:
- Motherboard: Gigabyte H310N 2.0
- CPU: Intel i5-9400
- GPU: Gigabyte GeForce GTX 1050 Ti D5 4G
- RAM: Kingston 2x8GB DDR4 2666MHz HyperX FURY
- Drives: Western Digital 2TB Blue 2.5" (a 10TB HDD is coming in the future)
I have a lifetime Plex Pass subscription.
Options looks like this:
- CPU usage is “Make my cpu hurt”
- Directory is D:\Plex_Temp
- Buffer is 120ms
- Both hardware acceleration is enabled
- Relay is disabled
- Upload speed is set to 3000mbps (I have nearly 700-800mbps)
The 4K direct play is working smoothly both on local and remote network. But for some reason the transcode to 1080p (from 20mbps to 8mbps) is lagging. If I switch to 720p everything works fine.
My idea is that Plex for some reason is not using the GPU at all when trying to transcode. But on the dashboard I saw that the “hw” is active next to the video line. The audio is transcoded always to OPUS (I think that’s a problem too).
Any idea how can I fix this? I think the i5-9400 and GTX 1050 Ti is more then powerful for this 1080p transcode and smooth playback.
Thanks for any help in advance.
