Plex on my Samsung TV skips subtitles
samsung-smart-hub
#1
What the thread says or sometimes it will show them later than their supposed sync time for a fraction of a second. Then it will show the subtitles perfectly, then skip some, etc.
Is it a problem of the Samsung Plex app, is it my router's problem? Subs are perfectly synced btw. They have been tested before in normal playback on my PC.
#2
This can happen on a low end TV, don't know if you have one.
You can have the server do the heavy lifting by switching to transcoding, if your PMS is fast enough of course.
#3
It's the 48H6400 so I don't think it's that low end. As for the other part, won't the transcoding mean reduction of picture quality? I have it on direct play now.
Could you elaborate the part of PMS being fast enough, please? Not the most knowledgeable guy here. I assume it has something to do with the local connection I did on my TV with the PC server when I added the PMS.
#4
Please download the manual and read that first, many questions are already answered in there.
Follow the link in my footer.
#5
I've read some of the manual.
I have it on direct play, so transcoding doesn't come into play. I wonder if it's my router. If the wifi can't handle all this. It playbacks the film even the most demanding ones with high bitrate, seamlessly though.
I connected my TV now with the router via an ethernet cable to test if the subtitles thing disappears but I see it still streams via wifi. Any tips to have the playback only via ethernet?
#6
Update: Used the wired connection to no avail again. Same problem exists.
#7
I got the same issue. Subtitles (.srt) does very often play out of sync on my Samsung KS8005 (2016). If I play through Plex on my PS4 instead the subtitle is perfectly synced.
#8
You are in the wrong forum if you own a K series TV, it uses a different app.
Go here > https://forums.plex.tv/categories/smart-tvs
