Plex on Ubuntu after installed Sonarr and Jackett not reachable
server-linux
#1
Hello!
Installed Sonarr and Jackett yesterday, after this lost connection to Plex. 32400 is not loadable, clients not see Plex.
On Plex.tv I can see everything.When I check daemon, I got everything is ok:
plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2018-02-12 13:02:09 CET; 8min ago
Main PID: 6646 (sh)
Tasks: 102 (limit: 4915)
Memory: 276.5M
CPU: 1min 16.022s
CGroup: /system.slice/plexmediaserver.service
├─6646 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Server"
├─6647 /usr/lib/plexmediaserver/Plex Media Server
├─6671 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/Resour
├─6732 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Re
├─6757 Plex Plug-in [com.plexapp.plugins.WebTools] /usr/lib/plexmediaserver/Resources/Plug-ins-f54242b6b/Framework.bundle/Conte
├─6762 Plex Plug-in [com.plexapp.plugins.trakttv] /usr/lib/plexmediaserver/Resources/Plug-ins-f54242b6b/Framework.bundle/Conten
├─6763 Plex Plug-in [com.plexapp.agents.subzero] /usr/lib/plexmediaserver/Resources/Plug-ins-f54242b6b/Framework.bundle/Content
└─6897 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-f54242b6b/Framework.bundle/Contents/R
febr 12 13:02:09 77mc systemd[1]: Starting Plex Media Server for Linux...
febr 12 13:02:09 77mc systemd[1]: Started Plex Media Server for Linux.
What's next?
#2
Log files are next. Can you show me what you’re seeing in your logs? (tar.gz of the .Logs directory)
Also, what ports are you using for Jackett? PMS and Sonarr do not collide. Jackett is unknown to me. PMS has its block of ports in the 32400 - 32415 range + 1900 .
#3
Jackett runs on TCP port 9117 by default, but this is user configurable.
#4
May I have your logs please? A tar.gz of the ./Logs directory is best if you can’t get PMS to dump them out for you (settings - server - help - download logs)
