I’ll make this post while making an attempt to control my temper because at the moment I am seriously, and I mean SERIOUSLY, unimpressed.
When I started using Plex recently I vexed long and hard over the question of buying a Pass given the VERY limited number of times I use what it offers, which for me basically is remote access (used about twice a year) and sync (even less). Still, I coughed up and bought a Lifetime Pass which to be honest isn’t cheap. So I got everything set up. PMS installed on a Mac Mini server at home and which I went out and bought JUST for Plex. Mac Mini set to reboot after power failure, automatic log in enabled, power saving off and PMS set to run at log in.
Came away for a few days and first day I checked it. Working fine. Great! Today, cannot connect!!!. Few times I tried I got the “Direct connection not available” so I tried indirect. Couple of times worked. Mostly, not. So. $150 for what so far!!! Boy, am I not happy. Seemingly wasted money AND I can’t watch my stuff.
So what gives? As far as I can see the weather back home may have caused a power cut. But it should power up and then be available right? I tested this dozens of times before I came away and it all worked ok. I made sure to access the server over the phone’s own internet too, not wifi, thus ensuring it was remote access that was working, figuring it’d be easier to sort out remote problems while I’m sat next to the damn thing than a thousand miles away. Also, the times that the awful indirect access HAS worked seems to indicate that the problem is not with my server not being up and running right? Because if it wasn’t running correctly why would indirect work at all? What does indirect access do to access my server that I can’t?. Be interested in the answer as I have to figure out which path to take in the ‘Get Plex to work’ maze in order to ensure I DON’T get a repeat of this s##t!
I’m hoping it’s not a problem with the damn firewall certificate access problem discussed a lot, which seems to STILL be unfixed, and which I’ve also been plagued with. Need to allow the connection EVERY time!!! I mean WTF? That needs sorting ASAP as that will screw up remote access no matter what you do if PMS is stuck in hold mode waiting for me to fly home and grant the firewall access!!! I thought I’d got this fixed with the terminal script but who knows? I won’t be impressed when I get home if I see a message on the screen saying “Would you like to allow Plex to accept incoming connections” THAT’S for sure!!!
I suppose I could have disabled the Firewall. Yeah, like that’s gonna happen. Or installed a remote desktop app at yet MORE cost over the $150. But, in all honesty, at $150 I didn’t anticipate these problems and perhaps not unreasonably expected this to just work! Especially given the numbers of times I tested it.
At one point I thought it might be because I had a double NAT issue here at the receiving end for a while. But that’s now fixed and I also tried to connect via the phone’s own internet. No joy. So doesn’t look like that was the issue. Plus, any double NAT problems should be at the server end right? Not the receiving end.
I’m stuck now trying to figure what is. As it is, it looks like Plex was a bad decision for me and a seriously bad investment given the FIRST time I come away it packs up. Double whammy for us as my wife is also away and she ALSO cannot watch anything. Great. Just f great!!! Doubt there’s much I can do now until I get home. Fat lot of use that is!!! Should have just stuck with Netflix which DOES work and also stuck with the laptop and a portable HDD which also always worked and saved myself the $150 because at the moment it seems like it’s $150 down the drain simply to do it differently and avoid having to take the laptop and HDD away with me. Different yes. Better, or even as good as, not by a long long long way. Had I not opted for Plex, not bought a $150 support the developer Pass, I’d have the laptop and HDD and now be able to watch my stuff. If I have to take the laptop away as a back up. What’s the point? Why pay for Plex in the first place?
I’ll try and sort it after I get back. Back into the Plex maze. Set it all up AGAIN. Test it all again and again and again and again. But if I have a problem next time I come away Plex is gone and I’ll write the $150 off as a serious screw up. Because for me, one thing is sure with Plex. Reliable it ain’t!!!
