Hi I just open a plex player in PS4 and it crashes everytime. we can use it for 1 or 2 seconds after that app freezes itself. I open the app and tried several times but no luck. anybody experience it?
Can’t say I’ve experienced much crashes with it… it dishes out the odd usual error with a blue background if left suspended for over 30 minutes but apart from that it runs flawlessly for me. Have you tried restoring your consoles database?
You could also try deleting the app and re-downloading it.
Thank you for the reply mate. No I haven’t tried it. It worked fine until I update my PS4 system software to version 5.
I see.
Players have been getting this error E-801809A8, it has been known to render their consoles useless.
If I was in your situation - I would call PlayStation support.
U.S. - About Us (US)
U.K. - PlayStation Support
Quick note, it’s recommended to call them for problems relating to 5.00.
You’re welcome.
@“hit play” said:
@Anuruddha said:
Thank you for the reply mate. No I haven’t tried it. It worked fine until I update my PS4 system software to version 5.I see.
You’re welcome.
It’s not the problem. I haven’t received any error code after I upgrade to the latest ps4 firmware. Everything in my ps4 works fine except plex. It freezes after couple of seconds.
You’re welcome.
Okay.
Did you rebuild the database? like I advised earlier. I also advised deleting the app and re-installing it to see if that fixes it.
No I haven’t rebuild the database or reinstall the app. I will try to reinstall it. Let’s see will it help.
One of them should fix it but I can’t promise anything.
If rebuilding or re-installing the app doesn’t work, contacting PlayStation would be your best bet.
@“hit play” said:
@Anuruddha said:
No I haven’t rebuild the database or reinstall the app. I will try to reinstall it. Let’s see will it help.One of them should fix it but I can’t promise anything.
I uninstalled the plex app and reinstalled it. But nothing works but app gave me a error “Direct connection unavailable” and a link to https://support.plex.tv/hc/en-us/articles/216766168
**So what I did is gone to SETTINGS->NETWORK and Secure connections = disabled. **
Then I open the app. It worked like a charm
may be PS4 plex app not yet supported to secure connections
Then I open the app. It worked like a charmmay be PS4 plex app not yet supported to secure connections
Glad you got it sorted.
Thank you.
I tried this just now. It did not work for me. App still crashes after few minutes of video playback. This is NOT the solution to error 34878.
I’m very sorry to hear it. Plex PS4 app seriously need a bug fixes. Now its been long time plex haven’t release any update for PS4 apart from xbox one. Please Plex fix it asap. thank you.
