Plex VR Bug Found
plex-vr
#1
When watching 180 or 360 degree videos, skipping through the video (using either the skip ahead/back buttons or clicking a point in the timeline) causes the video to reset to normal view. Thus, if you are watching a video and want to skip back ten seconds, you would then also need to reset the view afterwards. It's an annoying bug that I hope can be fixed soon.
#2
Hi, you can check this post for your problem.
https://forums.plex.tv/discussion/305189/how-do-you-save-the-sbs-setting
#3
In theory we fixed this in v1.2.0 of the app:
https://forums.plex.tv/discussion/comment/1615128/#Comment_1615128
Isn't the fix working for you?
