This morning I opened my plex server on my pc using Google Chrome. I always use Google Chrome for it on my pc and it always worked fine.
This morning however I get an error saying plex.tv can’t be reached. I restarted my pc, cleared my cache in Chrome,… nothing seems to work.
However, when I open an incognito window and go to the same site, I can log in and then it works fine.
How can I solve this?
clear cookies and history see if that helps
edit: whitelist plex in ad block plus or disable for this site will work
This ^^^
Also applies to uBlock or uMatrix and similar “filtering” browser add-ins.
Disabling AdBlock Plus on app.plex.tv did the trick indeed! thanks a lot @caveman31
Strange that it’s broken now
I’m facing the same issue with my QNAP NAS which cannot connect to plex.tv.
My QNAP is running version 4.5.3.1697 and Plex is running version 1.23.3.4707.
Is someone facing the same issue?
I do not have any rules set on my ethernet interface so I do not understand why it blocks.
@dazria
are you using a browser to watch plex or an app?
I’m using a browser to connect to the server
