Hi everyone, I’m running plex on unraid. Today I got this error after a restart:
ibc++abi: terminating with uncaught exception of type soci::soci_error: sqlite3_statement_backend::prepare: file is not a database for SQL: PRAGMA cache_size=512
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.43.0.10492-121068a07/PLEX MEDIA SERVER/8406dd53-15fc-4109-07d561b5-cd33b4f1.dmp
What can I do to solve it? should I contact the server support directly?
I tried it, first I went with automation and reindex, but it didn’t work.
Then I tried repair and now the error log changed to
[custom-init] No custom files found, skipping… Starting Plex Media Server. . . (you can ignore the libusb_init error) Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE) Starting Plex Media Server. . . (you can ignore the libusb_init error) Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE) Starting Plex Media Server. . . (you can ignore the libusb_init error) Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE) ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.43.0.10492-121068a07/PLEX MEDIA SERVER/85042354-5b5d-4c85-93e5f28d-cd4f5b69.dmp
and if I check the db again I got this
Enter command # -or- command name (4 char min) : 3
Checking the PMS databases
Check complete. PMS main database is OK.
Check complete. PMS blobs database is OK.
Checking FTS (Full-Text Search) indexes
No FTS4 tables found in main database.
Enter command # -or- command name (4 char min) : 6
Backing up of databases
Backup current databases with ‘-BACKUP-2026-04-08_12.12.15’ timestamp.
Reindexing main database
Reindexing main database successful.
Reindexing blobs database
Reindexing blobs database successful.
Reindex complete.
