PlexBMC skin
other-skins
#1
Hi guys,
I searched and searched but I didn´t find anyhing that would help.
Do to missing Addons in Plex I was forced to switch to Openelec with PlexBMC.
Unfortunately there is no real fancy skin. Amber works fast but its not a beauty.
Is it possible to make conq Plexbmc compatible or Plex Black edtion somehow available for Kodi?
I´m desperate...
Regards,
HS
#2
The titan skin works with plexbmc and is fairly customizable. There's also the Night skin which works well also.
Most skins can be adapted work with plexbmc so long as the skin allows custom home screen entries. Sometimes not so eligant but some do it better than others. I don't think I ever tried with the conq skin though
