PlexConnect running on QNAP NAS : Failed to Connect to port 443 Address Already in Use
Hello, I have a QNAS T251+, which is also running my PlexMedia Server. I want to run the PlexConnect to be able to see all in my Apple TV3. I have all the sw (phyton 2.7x, PlexConnect , the trailers certificate) installed on the QNAP. I have changed the QNAP WebServer Port to 81 (to release the port 80) and have disable HTTPS on the QNAP, to release the port 443. However, I am still getting the "Failed to connect to HTTPS on 192.168.1.113 port 443: [Errno 98] Address already in use
05:12:19 PlexConnect: WebServer_SSL not alive. Shutting down."message.
Using netstat, I can see this :
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:4433 0.0.0.0:* LISTEN
tcp 0 0 192.168.1.113:53365 45.79.211.86:443 ESTABLISHED
tcp 32 0 192.168.1.113:56794 52.17.111.136:443 CLOSE_WAIT
Any ideas of what can I do?
Many thanks!
