yes, that has to be the ip of your NAS
Did you disable GDM in the network preferences in Plex/Web?
anyway, plexGDM is not needed, it is just for discovery? just put the ip of the plex server in the settings file...
connecting with ATV should be visible in the log since the DNS is working. Do you see that?
Thanks for your suggestions.
Not 100% sure what you mean by disable GDM.
I've just gone into settings.py and changed it to:
#!/usr/bin/python
Global Settings...
# Plex Media Server
def getPlexGDM():
return False # True: use PlexGDM (GoodDayMate) to auto discover PMS <<CHANGED THIS TO FALSE
def getIP_PMS(): # default IP, if GDM fails... todo: do we need this fall back?
return '192.168.1.85' << CHANGED THIS TO MY IP OF MY SYNOLOGY NAS/PLEX SERVER
def getPort_PMS():
return 32400
# DNS/WebServer
def getIP_DNSmaster(): # Router, ISP's DNS, ...
return '8.8.8.8' # google public DNS
def getHostToIntercept():
return 'trailers.apple.com'
Is this what you mean?
When I started plexconnect using ./PlexConnect.py I got the same where it just stops at:
WebServer: WebServer: Serving HTTP on 0.0.0.0 port 81.
WebServer: ***
It doesn't do the PlexGDM bit.
If I access the apple trailers from the atv3 it says:
PlexConnect
No Response from Plex Media Server
Then on my log I get:
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect : Press ENTER to shut down.
PlexConnect : ***
PlexConnect : IP_self: 192.168.1.85
DNSServer : ***
DNSServer : Starting up.
DNSServer : intercept trailers.apple.com: 192.168.1.85
DNSServer : forward other to higher level DNS: 8.8.8.8
DNSServer : ***
DNSServer : DNS request received!
DNSServer : Source: ('192.168.1.111', 57949)
DNSServer : Domain: trailers.apple.com
DNSServer : ***intercept request
DNSServer : -> DNS response: 192.168.1.85
DNSServer : Source: ('192.168.1.111', 59341)
DNSServer : Domain: p6-buy.itunes.apple.com.akadns.net
DNSServer : ***forward request
DNSServer : -> DNS response from higher level
DNSServer : ^C received.
DNSServer : Shutting down.
WebServer : ***
WebServer : WebServer: Serving HTTP on 0.0.0.0 port 81.
WebServer : ***
WebServer : serving application.js
WebServer : serving /volume1/PlexConnect/assets/plexconnect.xml
WebServer : serving .xml: /library/sections
XMLConverter : Unable to connect to 192.168.1.85:32400
Reason: [Errno 111] Connection refused
XMLConverter : No Response from Plex Media Server
WebServer : serving /volume1/PlexConnect/assets/search.xml
WebServer : serving .xml: /&PlexConnect=Settings
WebServer : serving .xml: /channels/all&PlexConnect=Channels
WebServer : ^C received.
WebServer : Shutting down.
PlexConnect : ^C received.
PlexConnect : Shutting down.
Is this perhaps just a firewall issue?
Thanks in advance for any suggestions.
