plexmediaserver service won't start
server-freebsd
#1
I'm running plex in a FreeNAS jail. I'm NOT using the plugin.
After upgrading plex, I always got an error 22 when using curl to upgrade the library. So, decided to stop/start the jail that plex is in.
Now the plexmediaserver serivice won't start and I get an error about it not being in /etc/rc.d or in the local startup directories, /user/local/etc.d. But, service -e shows that it IS in the local startup directory!
root@plex:/ # service -e
/etc/rc.d/cleanvar
/etc/rc.d/newsyslog
/etc/rc.d/syslogd
/etc/rc.d/virecover
/etc/rc.d/motd
/usr/local/etc/rc.d/plexmediaserver
/etc/rc.d/cron
root@plex:/ # service pexmediaserver status
pexmediaserver does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
root@plex:/ # service pexmediaserver start
root@plex:/ #
Can someone tell me what to do to get plexmediaserver running?
Thank you.
  • nello
#2
Nevermind. Obviously, I mispelled plexmediaserver.
I'd delete this thread if I could see how. Feel free to do so.
#3
About the curl error 22, IIRC curl exits with 22 if it gets any HTTP error higher then 400 (or at least the 40x... - best to check the docs to be sure).
It might be that you're not sending a Token to authenticate and so you get a 401.
