PlexVR fails to start
plex-vr
#1
I have a Pixel XL on 8.1 (beta play services).
Every time I start Plex VR, I see the two Plex banners and then the login. If I enter my info, it crashes while logging in. It I use the Pin method, I can get past the login to 3-dots in the screen and a box above that says this device. Then it crashes. It is just Plex that crashes as I am booted out to the Daydream field.
This is the only app that doesn't work. I have rebooted, uninstalled, reinstalled, cleared cache, checked permissions and in every combination and order. It just won't load. It is making me nuts.
#2
Sorry you're having issues with the app.
I've checked our crash reporting tool and for some reason your crashes don't seem to be showing up there. In the future we want to support sharing device logs manually (just like Plex for Android does) but until then I'm not sure what to suggest, sorry (you seem to have tried everything already).
Not that it will make you feel better or anything but we have tested the app on a Pixel XL ourselves and never experienced this crash. Wonder if it's the beta play services that's causing it? Probably not, but it's the only thing that stands out from your description.
