PMP 1.3 breaks hardware decoding on Atom/ION
plex-media-player
#1
I am using an Acer Revo R3700 running PMP embedded. It has an Intel Atom CPU and Nvidia ION graphics and worked flawlessly. However since it updated to PMP 1.3 this morning, hardware decoding no longer works. This makes it unusable as it will not play any HD video smoothly without hardware decoding.
Is there somewhere I can download the previous version? As my HTPC is now totally useless.
Playback log please? Nothing should have broken it, although ION tends to be a bit flaky.
#3
My apologies, here we are.
#4
Any chance you could run vdpauinfo on the device and post its output here?
#5
display: :0.0 screen: 0
API version: 1
Information string: NVIDIA VDPAU Driver Shared Library 340.102 Mon Jan 16 12:41:40 PST 2017
Video surface:
name width height types
420 4096 4096 NV12 YV12
422 4096 4096 UYVY YUYV
Decoder capabilities:
name level macbs width height
MPEG1 0 8192 2048 2048
MPEG2_SIMPLE 3 8192 2048 2048
MPEG2_MAIN 3 8192 2048 2048
H264_BASELINE --- not supported ---
H264_MAIN 41 8192 2048 2048
H264_HIGH 41 8192 2048 2048
VC1_SIMPLE 1 8190 2048 2048
VC1_MAIN 2 8190 2048 2048
VC1_ADVANCED 4 8190 2048 2048
MPEG4_PART2_SP 3 8192 2048 2048
MPEG4_PART2_ASP 5 8192 2048 2048
DIVX4_QMOBILE 0 8192 2048 2048
DIVX4_MOBILE 0 8192 2048 2048
DIVX4_HOME_THEATER 0 8192 2048 2048
DIVX4_HD_1080P 0 8192 2048 2048
DIVX5_QMOBILE 0 8192 2048 2048
DIVX5_MOBILE 0 8192 2048 2048
DIVX5_HOME_THEATER 0 8192 2048 2048
DIVX5_HD_1080P 0 8192 2048 2048
H264_CONSTRAINED_BASELINE --- not supported ---
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
HEVC_MAIN --- not supported ---
HEVC_MAIN_10 --- not supported ---
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported ---
Output surface:
name width height nat types
B8G8R8A8 8192 8192 y Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
R10G10B10A2 8192 8192 y Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
Bitmap surface:
name width height
B8G8R8A8 8192 8192
R8G8B8A8 8192 8192
B10G10R10A2 8192 8192
A8 8192 8192
Video mixer:
feature name sup
DEINTERLACE_TEMPORAL y
DEINTERLACE_TEMPORAL_SPATIAL y
INVERSE_TELECINE y
NOISE_REDUCTION y
SHARPNESS y
LUMA_KEY y
HIGH QUALITY SCALING - L1 y
HIGH QUALITY SCALING - L2 -
HIGH QUALITY SCALING - L3 -
HIGH QUALITY SCALING - L4 -
HIGH QUALITY SCALING - L5 -
HIGH QUALITY SCALING - L6 -
HIGH QUALITY SCALING - L7 -
HIGH QUALITY SCALING - L8 -
HIGH QUALITY SCALING - L9 -
parameter name sup min max
VIDEO_SURFACE_WIDTH y 1 4096
VIDEO_SURFACE_HEIGHT y 1 4096
CHROMA_TYPE y
LAYERS y 0 4
attribute name sup min max
BACKGROUND_COLOR y
CSC_MATRIX y
NOISE_REDUCTION_LEVEL y 0.00 1.00
SHARPNESS_LEVEL y -1.00 1.00
LUMA_KEY_MIN_LUMA y
LUMA_KEY_MAX_LUMA y
#6
From all what I can see, it should work. I suspect the FFmpeg vdpau implementation is returning an error, but doesn't log any messages about it, so it silently falls back to software decoding.
At this point I have no idea what change could have caused the regression, so some more testing is needed.
Can you upload a small part of the file (just a few seconds)?
If you want to get adventurous, you could do some testing on the command line for us (we don't have the device):
- stop PMP
- start it on the command line with: VDPAU_TRACE=1 VDPAU_TRACE_FILE=vdpau.txt plexmediaplayer
- try to play a file, stop playback, and exit PMP
- upload the vdpau.txt
If there's no such text file after running, then the vdpau debugging layer is not part of LE and we need to find a better idea.
#7
Which file? Anyway, here's the other part you asked for. This is the console output:
PlexMediaPlayer:~ # VDPAU_TRACE=1 VDPAU_TRACE_FILE=vdpau.txt plexmediaplayer
libpng warning: iCCP: known incorrect sRGB profile
Logging to /storage/.local/share/plexmediaplayer/logs/plexmediaplayer.log
[1438:1488:0511/180000:ERROR:cookie_monster.cc(1543)] Found 1 duplicate cookies for host='plex.tv', with {name='_mkra_ctxt', domain='plex.tv', path='/'}
[1495:1548:0511/180002:ERROR:ffmpeg_demuxer.cc(1512)] OnReadFrameDone result=-541478725 IsMaxMemoryUsageReached=0
And I have attached the vdpau.txt file for your perusal. I cannot exit cleanly (ctrl+c) from that command you gave, so I have to kill the ssh connection and that's when it writes to the file.
#8
Just to confirm it's not affecting all Atom or ION...I run a Zotac ZBOXHD-ID41-PLUS with PMP embedded 1.3 in my master bedroom and have not run into any issues. I watched the first 15 minutes of a Bluray remux of Avatar and confirmed hardware acceleration was working.
He's asking you for the file (or sample) you are trying to play which causes the issue. Does this happen for every video?
#9
Oh right. Yes it happens on every video since the update to 1.3.
#10
Thanks for the trace log, it's very helpful.
I'm still puzzled as to why this happens. The only things that could fail should not fail, and the fact that other users are fine adds to the confusion. In the worst case we'll have to make a new test build just to add some logging to see what's going on.
A sample file would still be appreciated (just to be sure). Also can you post a playback log with an older PMP version, which uses hw decoding successfully?
#11
If you can provide a download for the previous version of PMP (1.2.5 I think?) I will be happy to do that.
The forum won't allow me to attach an mkv so I've uploaded it here: https://files.tehguy.net/misc/sample.mkv
#12
Please provide place to download the previous build. 1.3.0 broke my Plex media player playback as well, though a different issue: https://forums.plex.tv/discussion/270488/no-ac3-dts-sound-after-upgrading-to-pmp-1-3-0-rpi-embedded#latest
#13
You can download 1.2.5 from https://www.plex.tv/downloads/
#14
Thanks.
Right, this is interesting. I tried a nightly build of 1.3.0 that I found the link to whilst looking into a separate problem I'm having with PMP on a RPi3 not having any 5.1 audio since 1.3.0.
I put the 1.3.0 (generic) nightly build on the Atom box. As soon as it booted in, I tried a video and HW decoding worked. I then went through and tweaked all the settings (to get sound working, etc) and tried to play the same video and HW decoding did not work, for any videos subsequently.
So I reflashed the 1.3.0 nightly, and HW decoding worked again. This time I went through changing the settings one by one and test playing a video each time to see if HW decoding still worked.
Sure enough, HW decoding breaks after I enable Display mode switching. It seems to permanently break it too, as even if I subsequently disable display mode switching, HW decoding still does not work for any video. Only a reboot 'fixes' it.
I then allowed the automatic update to take it to 1.3.1, which is exactly the same. Enabling display mode switching breaks HW decoding, until display mode switching is disabled and the machine rebooted.
#15
That's a great find. This makes sense to me, although I'm wondering why I couldn't spot it in any of the logs. Maybe the trace log was overwritten at one point due to how vdpau (the underlying driver interface for hardware decoding) gets "lost" on display mode switching. This is called preemption handling. Preemption handling probably got somewhat broken in a recent change to adapt to FFmpeg API changes.
Until this gets fixed, you could try another method. Create a file named mpv.conf in the same directory as plexmediaplayer.conf, and add the line opengl-hwdec-interop=cuda. This uses another driver API for hardware decoding. The nvidia drivers we use are relatively old though, so I don't know how well this will work, if at all.
#16
Have tried your suggestion and it didn't fix it. I did notice in the info overlay it now says Hardware Decoding: no (-)
Before applying your suggested fix it would say something like Hardware Decoding: no (vdpau-glx)
#17
2017-05-18 09:22:38 [ DEBUG ] PlayerComponent.cpp @ 505 - opengl-cb: Loading hwdec driver 'cuda'
2017-05-18 09:22:38 [ DEBUG ] PlayerComponent.cpp @ 505 - opengl-cb/cuda: Failed to load CUDA symbols
Pretty opaque error, but we probably don't ship the required parts of the driver, or it's too old.
#18
Does that mean it's the end of the road for PMP on Atom/ION hardware then? Or stick to 1.2.5 for the foreseeable future?
#19
If it's really display mode switching, then I've already implemented a fix. I've also pushed it to the CI (although I'm not sure whether it'll get picked up correctly). If everything goes well, a new embedded build should appear in public-test on nightlies, which will probably fix it. I won't be around until Monday starting from right now to confirm it, though.
#20
Could I ask what you see on the screen when you play a HD video, as I have an ASRock ION 330, and when I play something with display mode switching turned on I get a sort of triangular break up of the picture, however I tried Libreelec with Plex for Kodi with display mode switching turned on, and it worked perfectly.
