Server Version#: 1.16.1.1246
Player Version#: 2.35.1
I’m running Windows 7 SP1 64-bit in a VirtualBox VM, running on Linux Mint 17.1.
When I try to launch PMP, It briefly appears on the task bar, then goes away. In Windows Task Manager, there is a PMPHelper.exe that starts when I try to launch PMP, but it does not go away. It doesn’t matter if PMPHelper.exe is already running, or if I kill it before trying to launch PMP.
Several versions ago (don’t know how many), PMP would generally work. At times I had to kill PMPHelper.exe before launching PMP, but that always did the trick. Now, it doesn’t help.
I’ve attached the Plex logs, captured just after an occurrence of the problem. I don’t see anything obvious, but I attached them just in case. Windows Event Viewer doesn’t have any events that mention PMP. I’m not sure what else to look for.
Good news: I had an old version of Plex Media Server installed on this VM, as well as Plex Home Theatre. I uninstalled both of these, as well as PMP, and cleaned up the folders they left behind. Then I re-installed the latest PMP, and it is working.
When I launch PMP now, I initially get the following:
Once I dismiss this, PMP launches and appears to operate normally, so it doesn’t seem to be a catastrophic problem, but I wonder if anyone knows what’s going on, and can I do anything about it.
I am waiting to hear from some someone that knows Windows more than me. Wonder if it is a 32bit vs 64bit thing.
your helper log indicates it made some crash dumps but I they were probably deleted when you uninstalled. C:/Users/Ken/AppData/Local/cache/PlexMediaPlayer/crashdumps/
