PMS 1.7.1 DVR doesn't record in .ts anymore
They have always stripped the closed captions from the remuxed MKV files.
It was stated in September that “we had to disable it for now b/c some formats of subtitles cause issues”: https://forums.plex.tv/discussion/comment/1267127/#Comment_1267127
Adding then back has been “added to our list for review” at least since October: https://forums.plex.tv/discussion/241667/feature-request-extract-subtitles-closed-captions-during-transcode
Thanks for the links… but now this makes the situation worse that they are remuxing for EVERYONE. If they are having issues with something then they should make it OPTIONAL with a warning that they are not including subtitles, not mandatory. Major, major design/implementation failure.
so the solution is to put TS files back
I have a script that pulls CCs from the TS, and remuxes everything to an MKV.
was working perfectly.
Now… with no TS… I am stuck.
Why hasn’t someone from Plex chimed in yet?
I don’t get it either…
I ended up reverting back to v1.5.5, as I need the DVR recordings to be in the .ts format. This way I can use Smart Cutter to manually edit out commercials with precision to add the recording to my library. From what I’m reading, I will need to stick to the older version from this point forward? I hope Plex puts the .ts option back.
@Wiidesire How are your profile script additions affected by the recent change? (Moving back to .ts)?
The profile.conf editing from here?
https://forums.plex.tv/discussion/comment/1445431/#Comment_1445431
You can delete those lines and my original guide (see signature) is now valid again.
@Wiidesire thanks!
It seems after the change back, the .ts files have no Closed Captions? Is anyone else experiencing this? @Wiidesire have you experienced this?
working fine for me.
I have me scripts to extract (that I has writen pre-1.7.1
with the switch back, my scripts once again work
