PMS crash on MacOS Lion
server-mac
#1
Hi there,
I just updated my Plex Media Server on my old Mac Mini - the web-interface told me, that a new version was available, and I hit "Upgrade" like so many times before.
However this time, PMS did not start after the upgrade. When attempting to start the process manually (in bash) gives:
Mac-mini:MacOS thomas$ ./Plex\ Media\ Server
Illegal instruction: 4
(see the crash report below).
I suspect, that Plex no longer runs on Lion... (Had hoped that the installer would have told me that I was attempting upgrade to an unsupported version...)
If that is indeed the case, I would like to know where to download an older version - preferably the most recent running on 10.7?
/Thomas
Process:         Plex Updater [9445]
Path:            /private/var/folders/*/Plex Updater.app/Contents/MacOS/Plex Updater
Identifier:      Plex Updater
Version:         ??? (???)
Code Type:       X86-64 (Native)
Parent Process:  ??? [1]
Date/Time:       2017-08-04 18:14:47.726 +0200
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Crashed Thread:  Unknown
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fff5fc01028
Backtrace not available
Unknown thread crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000055  rbx: 0x0000000000000000  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x0000000000000000  rsi: 0x0000000000000000  rbp: 0x0000000000000000  rsp: 0x0000000000000000
   r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000000000000000  r11: 0x0000000000000000
  r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x0000000000000000
  rip: 0x00007fff5fc01028  rfl: 0x0000000000010203  cr2: 0x00007fff5fc01028
Logical CPU: 1
Binary images description not available
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 11051
    thread_create: 0
    thread_set_state: 0
#2
@thomasnymand said:
Hi there,
I just updated my Plex Media Server on my old Mac Mini - the web-interface told me, that a new version was available, and I hit “Upgrade” like so many times before.
I suspect, that Plex no longer runs on Lion… (Had hoped that the installer would have told me that I was attempting upgrade to an unsupported version…)
/Thomas
Version:         ??? (???)
Report Version:  9
Logical CPU: 1
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 11051
    thread_create: 0
    thread_set_state: 0
Support for OSX 10.7.5 was withdrawn in May 2016 - announcement
Do you not have the download on your mac for the version you - which i presume was 0.9.16.6 ?
#3
Could you locate the Plex Media Server logs - would like to see how it managed to tell you there was an update
The logs are in this directory
Using the Finder’s Go menu, select Go To Folder...
then enter the following in the dialog box that pops up:
~/Library/Logs/Plex Media Server/
Please attach the Plex Media Server.log and other logs with names starting with Plex Media Server
#4
I have logs from other users and the problem is being looked into
#5
Problem has now been identified and fixed
#6
How has this been fixed.I can no longer access my media folder through my ipad pro but i can through my Playstation 4. The ipad pro says I need server 1.3 or higher required.
#7
The problem that arose in August 2017 where an old Mac running the last supported version of Plex Media Server got updated with an incompatible version was fixed in August 2017
The problem you have now is different. Your old 0.9.16.6.1993-5089475 version of Plex Media Server is still running on your old Mac.
Plex for iOS no longer supports old versions of Plex Media Server. This happened as from version 4.28 of Plex for iOS - see Release Notice text (copy here http://forums.plex.tv/discussion/comment/1655586/#Comment_1655586).
Notice of this happening was given in advance on march 20 - see http://forums.plex.tv/discussion/comment/1637821/#Comment_1637821 and also in the release note of the preceding version 4.27 released March 27 - see copy of text here http://forums.plex.tv/discussion/comment/1642515/#Comment_1642515
Old obsolete versions of Plex Media Server cannot remain supported by all the plex apps forever - that would impact progress and the ability to provide new functionality
