PMS not streaming and unable to access settings
Server Version#: 1.21.0.3711
Hi!
I have had this PMS running on my main PC for a few weeks now. After restarting the computer yesterday, my friend had issues where he could not play any file from the server. I tried as well, and no luck. I went into the settings to check the logs but got the “The settings are unavailable” message. I tried to fix it for some time, but in the end decided to uninstall PMS. I also had toremove everything related to Plex from the registry in order to get it working.
The server worked for the rest of the day and most of today, but now the same problem has once again arisen. Any thoughts/ideas as to why this is happening?
I am using a VPN, but I have been for the last month or so, so that should not be the issue (the problem also persists when I turn it off).
