Possible to DVR IPTV channels?
#1
So I just installed the IPTV.bundle channel, and attached my IPTV subscription to it. Works great, but I'm looking for something where I can DVR stuff from IPTV. Is this possible? I never watch live tv. I DVR everything and watch when I can. Any suggestions or guide links for doing this is appreciated.
#2
I want to do the same thing. Did you find a solution?
#3
Search för “M3u2Plex” on github and you will find what you are looking för.
#4
The instructions for M3u2Plex didn’t work for me. It never asks me to specify that it’s cable. I get almost all the way through but when I see the list of channels to add it asks me to select the channel guide for it and it only shows the over the air channels I’ve already added. When I check all the IPTV channels to add even without a guide it says it’s unable to add them. I’m wondering if others have this same issue due to some change made to plex since this last worked?
#5
so way can plex in there DVR set up add option to put IPTV log in and plex pulls all the channels itself.
#6
Something on those lines is being developed and posted about it here —> How to run Telly....??
Reddit thread here —> https://www.reddit.com/r/PleX/comments/7w3t6l/a_brilliant_project_that_allows_you_to_simply/
Note: Keep your channel list to less than 420 according to the author.
