Possible to track 2 split-apart movies separately?
server-windows
#1
I have a few items in my Plex library that were originally a single item. For example, if you download X-Men: Days of Future Past as well as The Rogue Cut of the same film, Plex sees them as the same movie and merges them into a single library entry.
I can do "Split Spart" and have them be separate entries in the library, but what I've noticed is that if I watch one of them and say, stop half way through, the other one is also marked as being in progress, the same number of minutes in. Since these two versions of the movie have different runtimes, this is not the desired behavior.
Is there anything I can edit in the two library entries metadate to 'uniqueify' these films in some way so that the runtime and status of one doesn't affect the other?
#2
Plex doesn't support different "cuts" of one movie. Nor has it any means to treat, what it deems two versions of the same movie, separately.
You have two options:
1.
- Unmatch one of the two versions
- then go to Match - "Auto match" - Personal Media
- fill in all the metadata yourself
2.
Same as above, but use TheMovieDatabase (TMDB) instead of 'Personal Media'.
Use this when your normal movie metadata agent is 'Freebase'.
If you use TMDB as your default agent, then match one of the versions against 'Freebase' instead.
#3
Method #2 seems to work when there's two, but what about if I have 3 similar cuts of a movie (for example, Star Wars despecialized, 35mm scan, and blu-ray).
I guess #1 would work, but what a pain. I just want to set the "id" or something so it stops trying to auto match to other entries. There's really no other way?
#4
Nope. #1 is the only option if you have more than 2 "cuts".
If you want each "cut" to appear as separate movie in the list and want to be able to sync it onto mobile phones or into the cloud, that is.
There is a simpler way: by treating those editions simply as Local Extras. But this means there is only a title to set them apart. No separate description or poster or anything of that nature.
All subtitles must be muxed in, as sidecar files are not supported for Local Extras.
Then you add the "edition" video file into the same folder as the main movie. Rename it so it contains any of the Local Extras name suffixes described here.
Movies /
Star Wars Episode V The Empire Strikes Back (1980) /
Star Wars Episode V The Empire Strikes Back (1980) - [theatrical] 1080p.mkv
Despecialised-scene.mkv
BluRay Version-scene.mkv
#5
I have succesffully split the 2 files (movie X-Men DOFP: Rogue Cut) but now when I play one version it shows both as being played and they are both showed under "Continue Watching". Why after splitting these is it treating it as if it is ONE movie?
#6
That's the way Plex works, unfortunately. It's been that way for years and isn't going to change any time soon.
#7
Because it really is the same movie. It is still X-Men.
If you really want Plex to treat your second version as a different movie, perform a 'Fix Match' on one of the versions.
The endgame is to have one version matched to the 'Plex Movie' metadata agent
and the other one to the TheMovieDatabase agent.
Then the two files are different movies to Plex.
#8
Technically not - there is X-Men DOFP (2014) and X-Men DOFP Rogue Cut (2015)
In the same way as Aliens and Alien SE etc.
The inability to recognise this is pretty much the only major failing of Plex in my view.
