Preferred NVIDIA SHIELD Internet Settings
server-nvidia-shield
#1
For those who have a SHIELD TV, what are the preferred internet settings that you imply on your device?
Do you enable IVP6? What is this anyway? Ethernet or WiFi?
If anyone can share this, that would be great and helpful. I have Verizon FiOS.
#2
I do not enable IPv6 it's the latest internet protocol, usually causes issues. I have Ethernet everything.
#3
Ethernet will always be more reliable than wifi... Wifi is subject to interfecence, especially in the 2.4ghz bands.
Other than that, I believe IPv6 works for Plex but generally it's still buggier/not as well supported as ipv4, so I have it turned off. Depends on your ISP, too.
