Primewire?
#1
Has anyone picked up the work done previously on primewire? My bookmarks for tv updates with programs but, none of the "links" work.
#2
Try installing the UnSupported Services Tools bundle it should provide you with a few working "links".
https://forums.plex.tv/discussion/224622/beta-unsupported-services-tools-looking-for-testers
#3
Hello and thanks to you all for making this such a very cool thing. I was wondering if there were any known issues with Primewire currently. I was having one and was just wondering if it was the storm outside or a ghost in the machine. Thanks and have a good one.
#4
Something is happening at Primewire that's making it unusable for everyone. Most of the sources that these unsupported Plex channels were using are being shut down.
#5
The channel creator PIP pulled the channel.
Thank you Mr. PIP it was a great ride while it lasted.
#6
Has been down for 3 weeks, but plugin still works on primewire.is, just switch to use that url in your settings. Will primewire website itself get sorted? only time will tell.facebook.com/Primewire . Another jump start movie site is in progress as refered too by primewire on facebook. streamdreams.org In case any coders would like to make a plugin for it
#7
Primewire.is no longer working.
#8
I think recently Primewire.IS site is currently down, Does anyone know if it will be back ?
