Pro vs 16GB?
server-nvidia-shield
#1
I plan to use my Nvidia shield as a PMS and would like to know whether having a 16GB model (with a USB attached) would perform worse off than the 500GB model. If it would can you explain what those disadvantages are?
Sorry if this topic has already come up, new to the forum.
#2
The Plex meta data can only be stored in internal memory. Get the pro, everyone that bought the 16gb for PMS ends up regretting it.
#3
You will, probably, have a terrible experience if you try to use the little 16gb Shield as a server. It, probably, will kind of work but you will be VERY limited as to what you can do.
Plex cannot use any form of attached storage for its database so there in a good chance you will run out of storage trying to use the 16gb Shield as a server unless you have a VERY small library or you turn off virtually every feature that uses any storage.
On the other hand (you have different fingers) the 500gb Shield Pro makes a wonderful server. During initial setup the Shield sometimes slows down and does not work well but once it finishes getting metadata and other info it speeds right up and works even better than the PC server I have with a processor that has a Passmark of over 8000. On top of that the Shield uses hardware transcoding and that allows even better performance.
So my vote for a Shield for a server is 16gb NO and 500gb YES.
#4
Just wondering how many Blu-ray rips will it transcode at the same time, also how many direct streams can it handle whilst using the shield itself for playback, I am planning on using a pro for my main tv with 3 new fire tv sticks in other rooms in the house, same ui across all these devices makes it a great wife acceptance factor.
#5
It should direct play just about anything on the Shield so anything playing on the Shield should have little impact.
As far as transcoding Blu-Ray rips that would depend on exactly how they are ripped. If you rip to a format that direct plays on the target device then there will be no transcoding involved.
I have no large Blu-Ray rips in my library as I cannot see (old eyes) any improvement between Blu-Ray and just good 1080p DVD rips so I cannot help there. All I know for sure is that Plex runs VERY smoothly on my Shield.
#6
My blu-ray rips are all h264 mkv with ac3 as the first track and he audio tracks as second and third tracks, these rips vary in size as I haven't re-encoded them from the original disc, I have tried to play these on the latest app for fire tv stick 2 this week, however it doesn't seem to have the horse power to be able to play full rips so I am using hardware transcoding to bring these down to 20mbps on the fly, it's working great on my i5 laptop with the hw transcoding preview but this machine is a temporary solution.
#7
What EB said and
Think about having your clients hardwired ( yes that means no Fire stick !) - one less issue when buffering starts!
#8
@spikemixture said:
What EB said and
I have the original and the 2nd gen fire stick, and have found the 2nd gen to work well with my ac wireless, however I do have to set a maximum bitrate of 20mbps, I don't think the stick can handle more than that, and I have some rips as high as 40mbps.
#9
Running a 16 gig 2015 shield with no issues attached to a 16T capacity nas with 10T of media. I do have some of the meta data options disabled. Also added 128 gig of internal storage. So far all is well.
#10
Just be aware that Plex cannot and will not use that internal storage.
#11
Audiomixer - your Shield 16GB will crash.
I had 128gb MicroSD Card and 128gb USB 3 Stick which do nothing (as pointed out above)
I tried several amount of media and a calculated guess would be around that 10TB of data mark.
I have all the things turn off as suggested many times.
It will CRASH !!
And from my experience it's a reset/reboot situation so all is lost on the Shield !
#12
So I’ve noticed, but at least enough other stuff was moved to the storage as to give plex some breathing room and eliminate the warning of low storage.
It will CRASH !!
Well so far so good though. Even have the homerun extend doing records and even that is working well.
#13
Just wanted to provide an update, I got the 500GB model now :-)
However just for anyone else, the 500GB has one feature missing thats in the 16GB model. The 16GB model's remote has a built in IR sensor whereas the 500GB doesn't.
Also the 500GB uses a hybrid drive (disappointing considering its 100GBP premium).
#14
It will CRASH !!
Yes but it WILL crash . You have been warned!
#15
It will CRASH !!
Been running for quite some time and no issues with plenty of ram left. Warning noted and thank you. I’ll let you know as soon as it crashes. Besides, I can always use my Mac mini as server too.
#16
@audiomixer said:
I will add one caveat - if you do not add more media you may get by.
But if you are adding additional media - I will be waiting for your acceptance speech :D
#17
In the same dilemna as the OP.
I have heard that it is possible to root the device and use symlinks to extend the internal storage to do away with the limitation.
#18
@ihshaikh
I run a 16Gb model (2017) and all the PMS's data are in the external storage (adopted).
Once rooted your Shield, you have just to uninstal PMS app (it is installed as system app), then enable (in developer options) the option to override manifest settings about the install location.
So just reinstall PMS, it will be installed as user app on the adopted storage.
I linked in somewere in the forum the detailed steps from xda thread.
If you don't find the post, let me know.
Edit: https://forum.xda-developers.com/shield-tv/general/guide-t3692061
#19
@goose2600
Thanks for the response - I'll see how I get on with the 16GB version - my main use case is for LIVE TV and DVR so not expecting the library to expand significantly.
In any case - is there a way to check the storage status of the device?
If down the line I run out of space I will then root the device and add additional storage as per the link you provided.
Regards
#20
You can check the storage status by going in the menu Settings --> Storage, just like a classic android device.
