QNAP plex won't load port 32400
#1
I upgraded my QNAP and the plex app today and now I can't access it. All of my other apps look good.
I tried uninstalling and reinstalling (I have 2000 movies so uninstall took forever).
Upon reinstall, I still can't hit http/s on port 32400.
Any logs I can check for obvious errors?
TS-870 Pro
CPU Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz
Firmware version 4.3.3.0154 Build 20170413
PlexMediaServer_1.6.0.3698-7fe404e94_x86.qpkg is the one I installed today.
#2
I answered my own question in case anyone cares.. The old version of QNAP (4.2.x) required the x86 version of plex, the new release (4.3.x) needs the 64bit version.
#3
Have the same issue and Im trying that right now , will let you know . Thanks
#4
Yep it worked :) thanks
Unfortunately I uninstalled my PMS before seeing your messages so I lost all my metadata and have to re-index everything. Now running v1.6
#5
I had the same problem. Now it works fine. Thanks for the hint!
