Hi, I’m running Plex on a QNAP TVS-1282, and the last week I’ve been getting more and more crashes (server just stops responding). It started out maybe once every two days, but now I’m down to at least three times a day. In the beginning I could just stop the Plex service in the QNAP GUI and restart it and it started running, now that doesn’t work and I need to reboot the whole NAS to get it up and running again. I just tried optimizing the database since last reboot 30 minutes ago, not sure if that will help. Any ideas would be very helpful! Attached are the logs.
I found a number of crash reports from your server. The crashes appear to be to do with the NAT/uPnP requests the server is sending to the router to establish the public IP address. A response is being returned by the router that is leading to the crash. last crash Jun 19, 2018 23:25:19.
I will pass it on to the development team but if the crash can easily be reproduced and you can have wireshark running to capture traffic between the QNAP and the router then that would help and show what response the router is coming back with
If you can do that - please save as pcap file and send to me privately together with the logs leading up to the crash
Thanks alot! I am running firmware 4.3.4 build 20180528. I will try running wireshark to capture the traffic, but after I had 3-4 crashes in a day (same day I wrote this topic) I got a bit fed up and deleted the Plex app and installed it again. Been stable so far since, so not sure when the next crash will be
The router I am running is a Ubiquiti USG firmware 4.4.22.
You want to verify the TVS is 4.3.4.0597 build 20180528 (which sounds right based on build date)
I cannot speak to the Ubiquiti as I use Netgate pfSense and have no UPnP errors.
Thank you all for taking the time to help me. Would specifying port 32400 manually under settings - remote access disable Plex attempting to go online with upnp?
Yes it would but … we also use uPnP to try and find out the Public IP Address from the router - if it fails it does not matter - it is an extra check which helps detecting for example Double NAT
Had two crashes last week, the last one just an hour ago. Same errors regarding the UPnP even though my Plex server is set to use a manual port. Attached are some fresh logs.Plex Media Server Logs_2018-07-03_15-23-27.zip (4.1 MB)
I do have a test development build with fixes for lockouts that I made available to a few users and I can make available to you to see if it makes a difference.
Plex Media Server version 1.13.4.5251 has just been released as beta. It has fixes for two deadlocks following investigations from diagnostics provided in this forum thread
