Random CPU spikes and network interruptions
windows-store-app
#1
So for a couple weeks now, The Plex App has started using a lot more CPU (usually < 1%) spiking up to 40% usage shortly after starting a stream from a Plex server on the local network, during this time, the App becomes unresponsive to controls but continues to play, continued clicking of controls results in the app crashing completely. Unfortunately I wouldn't really care about this minor inconvenience but whilst this is happening, all other network connections are disconnected / reset. Network usage is normally less than 20Mbps on a Gigabit network.
This occurs regardless of content being streamed. Any help would be appreciated.
#2
I suggest you to check the link, if this could be of any use…
#3
Thanks but I’m not using the web app, and all my content is streamable, and not being transcoded.
#4
sounds to me like your local sync cache is corrupted or something. have you tried uninstalling and removing every trace of plex on that machine then reinstalling it? (there are a couple of folders in the %AppData% folder that might cause the high spikes?
#5
Thanks, your suggestion has worked a treat so far (%AppData% folders, already tried reinstalling obviously), I also moved the sync folder (just to be on the safe side) off the 960 EVO NVMe drive as I recently noticed that too was hitting 100% activity during those times (adding further credence to your suggestion of corrupted sync cache).
Thanks again for your time.
