RARflix: modified Roku Channel
plex-classic-for-roku
#1
RARflix: v3.2.6 :: Add Channel @ https://owner.roku.com/add/rarflix ( updated 2014-08-16 )
   * NOWTV sideload zip: download @ github ( sideload works for any roku in dev mode)
    * Includes Now Playing: Info about Now Playing
    * Includes Profiles and Pins: more info
RARflixTest: v3.2.4 :: Add Channel @ https://owner.roku.com/add/rarflixtest ( updated 2014-03-28 )
_______________________________________________________________________________________
RARflixReset: v1.0 :: Add Channel @ https://owner.roku.com/add/rarflixreset ( updated 2014-02-24 )
    * ONLY use this if you need to reset your preferences to default
 RARflixTools - Supplemental Tools for RARflix
     * enable Watched/Progress indicator overlay on Posters
     * Requires RARflix v3.1.0+ channel
 Video: RARflixTest (it's a bit old, but it give you an idea of the changes)
 Roadmap / Wishlist / Bugs
 Current Test Change - v3.1.49
       Add Channel @ https://owner.roku.com/add/rarflixtest ( updated 2014-03-19 )
      Major changes since v3.1.0 (current stable release)
  • RARflix will work when myPlex is down - with the last known server(s)
  • Filtering and Sorting [WIP]
  • full grid as Default View per section [optional]
  • full grid inline sorting/filters using info () key
  • WOL (Wake on LAN) -- h/t @Talidan.
  • Put On Deck - use the info () key to see the option
  • clock/date options : 12/24 hour clock  + Date format/disable options
  • description button in the dialog pop up to show the non truncated description.
  • Include the ROLE of the cast member(s) if one exists ( Cast & Crew )
  • global search: will now search shared servers ( only searched local/owned servers previously )
  • complete rewrite of the Slide Show - moved from roSlideShow to roImageCanvas (can handle an arbitrary amount of items now) [WIP]
  • shortcut for the Home Screen from a dialog (remote * key)
  • Various Speed Improvements for the UI
  • focus on last used section when starting - broke due to merger of official channel
  • legacy remote: add a close button to the Reorder Screens
  • advance to next episode automatically ( preplay screen )
  • show preplay screen after direct play from grid
  • channel content: excluded from showing preplay screen after watching if played from grid
  • exit confirmation
  • music: new rows "first letter" and "recently viewed"
  • WOL - wake on lan options + keepalive
  • New Playback Option (simplified): Shuffle, Continuous Play, Continuous [context] Play
Version Details:
MAIN Release Info ( I will continue to add my release posts here )
All version of RARflix  have been merged with the most recent release of Plex v2.8.2    PlexTest v2.6.9 - ( 2013-09-17 )
Tested on: Roku3, Roku2, Roku LT, Roku 2 XS, Roku XDS ( please let me know of other working models )
  RARflix - What's Different from the Official Channel?
* Refer to "Release Info" for all changes ( I won't be updating these anymore ) (view full change log)
* User Profiles ( fast user switching ) h/t @wagnerscastle
* Pin Codes. h/t @wagnerscastle
* ALL v.2.7.0 Release changes
* full grid
* black theme
* custom thumbs
* 6 buttons
* music changes
* Now Playing section on Home Screen (more info - screenshots)
* Now Playing: Sync play with remote user (this only starts the video at the offset of the remote user)
                       When the sync button is clicked, the most recent offset is queries and used
* view change log above for current changes
* () "Info Button" now works in most areas of the channel
        - It will activate the "more..." button dialog
        - In the dialog, the (
) will close dialog
        - Search dialog will be used if the selected item doesn't have a specific dialog for the info button
        - should work for Global OnDeck/Recently Added Items, Movie Section, TV Section
* Cast and Crew for Movies: Check out the MORE button / "Cast & Crew" - Works with TV/Movies and supported  channels
        - Display a list of Actors/Directors/Producers and Writers for selected item
        - Persons poster will be displayed if your PMS has a URL for them (depends on the scaper)
        - Select a person to get a list of movies/tv/other content
        - Listed content will show Server/Section name on the top right
        - NOTE: people searches only work in the PMS by sections for now
        - This also doesn't work for TV shows yet. That's a PMS thing..
* Trailers: multiple enhancements
        - Play All Button (plays from selected video to the end of the list)
        - Navigation - You can click left/right in the Video Details Screen for the previous or next trailer
        - Video Length is now available. HUD has End Time & Time Watched
        - Directly Play a video in the list with the Play Button
        - Breadcrumbs are now updated ( empty before )
* Toggle for Trailers/Rotten Tomatoes search toggle - by "Title" or "ORIGINAL title" [default: title]
* Toggle for Critics/Audience Score: also display a * on the rating if the score used is not the preferred rating
* Complete re-write of adding custom rows ( currently the 2 "unwatched" rows for movies )
* Re-write of Hiding Rows:
        - One can hide Recently Added, Recently Released/Aired rows per section type [movie,show,music]
* Default limit of 200 items: New unwatched rows for Recenlty Added and Recenlty Released
        - Toggle to change limit is in rarflix prefs
* Remote Logging: If enabled, they will not go to PlexServers any more.
                              I suggest to never use this unless you are testing with me. If you are work with
                              a Plex Employee and remote logging, you shouldn't be using this channel
* Update breadcrumbs on the Global (home screen) Recently Added content - inclue the server name
* HUD: display current time and time watched when video duration is unavailable ( usually queue videos, some channels, trailers )
* SlideShow Overlay toggle: toggle for text overlay during slideshow (down button) -- request
* RARflix Preferences section: my mods that haven't made it into the Official Channel will usually be here
* Hide Rows: you can now hide rows instead of reordering them, which you can still do too. ( not per section though )
* Ability to toggle all mods ( well most of them )
* TV Shows watched status: will include (watched) or ( # of # watched) or (#) for TV shows. Not really new, but some fixes added and of course a Toggle to turn it off
* Toggle for the Clock
* Added 2 more rows: Recenlty Released (unwatched) & Recenlty Added (unwatched) -- movies only -- post
* HUD: display current time and time watched when video duration is unavailable ( usually queue videos, some channels, trailers ) -- post
* More Dialog: Will Display title of the Content and Short Description
* Merged Schuyler's updates from the PlexTest (v2.6.9) channel: http://forums.plexap...ku/#entry465759
* Add time/date to Main Screen
* New Dialog for Mark as watched/unwatched for partially watched content
* HUD: EndTime, Time Left and Average Bitrate added to HUD
* Movie Trailers: Streamed from Youtube (TMDb)
* More options (could be redundant) added to the "more" button
* Rotten Tomatoes integration for Movies ( user ratings default )
* Audio Preferences: DTS enable/disable option ( some receivers/tv/amps can't direct play DTS but can direct play 5.1 )
* Audio Preferences: Moved some settings under the advanced settings that have to do with Audio to this section
* ReFrames upped to 9 ( may direct play more media )
* HUD: includes Direct Play / Transcode info, Vid Resolution, Audio Channels, Audio Format, video container
* Playback options and Delete are moved into the 'More' dialog (for movies) - use the 'More...' Button
There were a few touch ups to the existing mods:
* movie watched status will show (watched+restarted) instead of just watched. Might explain why a movie is on deck yet watched
* TV season watched status breadcrumbs (top right of screen) cleaned up. Will no longer show watched status on breadcrumb to save space
* others.. but not really necessary to list
** Fixes *
- Show the option to Hide Rows in the preferred Row Order
- remove "invalid" from HUD when Release Date is unavailable ( usually queue videos, some channels, trailers )
- ability to delete queue items (only affected rarflix/rarflixtest )
- when browsing the global on deck (non shared users) entering a movie would allow you to click left or right. If the next option was not a movie, you were given the option to "play" the content which would result in a crash. Now we just limit the ability to click left or right - not really a complete fix, but will stop an accidental crash. (bug seen in official channel too)
crash when clicking the play button on a Photo folder (bug was only present in rarflixtest)
- updated logic in the more dialog for mark was watched/unwated; only show watched/unwatched when it make sense!
- Breadcrumbs updated when selecting "All Seasons of {ShowTitle}" or "Season {#}" insead of just diplaying "Series"
- Recently Added (unwatched), Recently Released (unwatched) rows could not be hidden
- Depending on how one entered a TV Episode, the more button wouldn't exist due to data missing from the PMS response. We now obtain the needed info another way when missing.
- Fix: TV marked as watched/unwatched does not function as it should - fixed: github
- Fix: crash when clicking the play button on a Photo folder (bug was only present in rarflixtest)
-- Wanted --
Please comment on this topic with your request - it will be added if possible
-- Changes ( now in the supported plex official channel ) --
* Enter a specific season/show from an episode
* Release date on HUD
* Clock on main Screen
* TV marked as watched/unwatched does not function as it should - fixed: github
GitHub: https://github.com/ljunkie/rarflix
    * RARflix:https://github.com/l...lix/tree/master
    * RARflixTest: https://github.com/l...rflix/tree/test
_
 Sideloading & Obtaining logs to fix a crash
  Step 1: Enable Developer Mode on the Roku
  • HOME 3 times, UP 2 times, RIGHT, LEFT, RIGHT, LEFT, RIGHT
  • Enable developer mode on the screen that comes up.
  • Download the most recent RARflixTest zip
  • In a web browser go to http://YOUR_ROKU_IP ( example http://192.168.0.100)
  • Click browse and navigate to the RARflixTest zip you downloaded
  • Click the install button
  • This will automatically start the side loaded channel. It will also be the "last" channel on the home screen.
  • NOTE: this sideloaded channel will not share settings with the existing installed channel. You may have to change some settings to get going.
  Step 2: telnet to the Roku on port 8085 to view the LIVE logs -- this will catch the crash and give us the info needed
  • open a command prompt, cmd.exe ( linux/osx, start a terminal )
  • telnet (YOUR_ROKU_IP) 8085
  • keep this window open while you access RARflixTest
  • try to cause the crash
  • attach the output to the existing forum thread
I
figured I'd share this here. I have customized the Roku channel just a little bit. It's ONLY small modifications, not an entire rewrite, so it will look almost identical to the normal Roku channel. I try and keep this up to date with any changes @ PlexInc's Git Repo . Meaning this will have all the updates the PlexTest channel has along with any updates not yet pushed. I'd also like to thank Schuyler for answering all of my questions! BrightScript is just lovely...
#2
Looks good. I'll load this up tonight and test it out. One thing that bothers me about the Roku player is that there isn't a way to see the progress of a video while it's playing. Is that something that can be added or is there limitations in the SDK around the player?
#3
Yea, I always wished I could add an end time. It is a limitation of SDK unless one were to rewrite a custom video player and I don't know what's all involved with that. Currently the only things supported in the default video player are title (line 1, top of HUD), length (line 2+, column 1) and release date ( line 2+, column 2)
* The Title is always the top line in bold.
* Length can only be an integer ( roku handles the conversion to human readable format )
-- column 1
* Release date: supports text. As you can see with transcoding, I am adding new lines but I believe it only allows for 3 lines ( not verified )
-- column 2
As of recently, it might be possible to update the HUD as the video plays, but I haven't yet looked into that. I'll put that on my list to check the possibilities. Currently I have another idea I am toying with which will bring happiness to many if I can figure it out :)
#4
Love it. The Rotten Tomatoes integration for Movies should be added to the main Plex channel, it just makes sense.
If you can add a shuffle feature for when we watch music videos that would be great.
#5
I'm using this and its pretty awesome. Any idea why subtitles play on some movies and not on others? I just got a Roku 3 a few days ago and it seems stream most of my bluray ripped mkvs. It did seem to rebuffer on Gi Joe Retaliation though, is there any way to change how much to buffer? I'm running this on gbit ethernet on a real Cisco switch, not linksys. Also Its not my server.
Any ideas on these things would be great!.
#6
Thank you.
There is no way to change the buffer as of now. Since you are a PlexPass memeber you can view the buffering feature request topic. Even if this was implemented at some point in the PMS, I would think the buffering capabilities also depend on the client so it doesn't mean it would just work for the Roku. Also note, that it's not your server so there are a few possibilities: the server didn't have enough upload bandwdith at the time, the server was busy, other internet downloads might have been occurring when you were streaming, etc..  If it gets choppy, you could also try and lower the quality for the duration of that stream.
Subtitles are also a lot of fun. I would look at these topics in the Roku forums or start a new topic in regards to your subtitles not working for some videos. It's not cut and dry as it depends on the subtitle format, media container and other possibilities.
#7
Thank you.
Thanks for the quick reply! Btw I clicked on your donate link and donated. I'll check out the buffering request area. What do you mean by its not my server? I'm talking about my local 138TB server. I use a Dell Rackmount R310 with a Xeon hooked to a few external SAS enclosures. I wasn't currently doing anything on my network when streaming and pretty much every MKV file I have tested so far has worked. I'm sure i'll run into others that don't. I use makemkv and rip directly from BD to mkv without re-encoding. I keep native Video and DTS/TrueHD etc audio streams. I direct played quite a few videos testing lastnight. The only one I noticed an issue with was my new GI Joe mkv.
Also my internet bandwidth isn't fast enough to affect my local media on my server and all my media players are segmented away from the rest of my network by having their own VLAN.
About the subititle thing. I actually think i read that internal subtitles in MKV don't work. I would actually agree if I didn't happen to notice an internal sub on 2 movies just starting showing, I was very suprised. Thanks for the info tho i'll look into the subtitle issue more and the buffering topic.
#8
I thought you meant it was a shared server when you said "Also Its not my server." I guess you meant the issue is not your server :) Thanks for the donation! That link is actually meant for plexWatch, but it's all the same to me.
#9
I was wondering if you would consider adding trailers to your mod.  I scrape my data from The Movie DB and most have YouTube links for movie trailers (that XBMC uses for their trailers).
I would like to be able to play these videos.  Possible??
great work.
#10
... Currently I have another idea I am toying with which will bring happiness to many if I can figure it out :)
great work.
I was trying to be sneaky :) Good things may be coming soon.
#11
You all might want to check out the first post of this topic. I have a new channel for testing RARFlixTest. It has support for Movie Trailers from Youtube.
 Please let me know of any issues. It is known that some videos will not play as some content on youtube is paid, locked and I just couldn't locate a playable mp4 file. The error you might receive is "Could not find any playable formats. Please try another video..."  -- which means exactly what it says, please try another youtube video :)
 Big thanks to 'jesstech' for the youtube code I found through a google search: https://bitbucket.org/jesstech/roku-youtube
#12
Hi ljunkie!
Any chance you can open up RARflixTest for all regions? (not available in my area)
#13
Hi ljunkie!
Never even noticed that option deep in there menu. How about now?
#14
Just made an update to the RARFlixTest channel
HUD Changes
rarflix-HUD-transcode-20130906-half-top.
#15
FYI, Your Plex test channel breaks the Youtube channel. If I attempt to play anything from the Youtube channel I get kicked out of Plex back to Roku's main menu. This does not happen with Plextest or the main Plex channel. This problem is not new with the latest update. The problem existed with the last version too.
#16
Thanks for the report. I don't use the youtube channel, but I guess I will try it now :) I'll post this as a known issue and find a fix for it.
Update: Fixed and pushed to both RARFlix and RARFlixTest as of 6PM PST ( just force an update on Roku )
#17
Truely awesome! Your hard work on this as well as PlexWatch is very much appreciated!
Donations coming your way, but more than that - appreciation! and Thanks!  :D
#18
Havn't tried this yet, but I'm assuming the Youtube trailer stuff comes direct from Youtube to the Roku and bypasses the Plex Server? I only ask as my Plex Server doesnt do transcoding. :D
#19
On the latest update of RARflix my delete function is missing.
#20
It's moved to the 'more' button. There are only so many lines to work with... please let me know if it works as I don't allow deletion on my server
Edit: I verified it shows up under the "more" button after I enabled 'allow deletion" on my server. However I don't have any media to delete, so let me know if it doesn't work.
