Raspberry Pi music server & player using Plex
plex-media-player
#1
Good Evening
Is it possible install Plex Media Server and Plex Media Player on a Raspberry Pi together?
I ask as I am thinking of building a music server/player that will be able to run Plex. The media will be stored on a separate Hard Drive (poss 500Gb laptop drive) and use a 7" screen. It will only be used for this purpose.
I have see YouTube videos on this but they use software like Max2Play but I don't like them as the interface layout is a bit naff (just my opinion). Plex is more simple. I have seen YouTube videos showing the server and player as separate devices but not on the same device.
I would house both units in a case with the screen on top and install a remote control device. Not really interested in mobile apps as a controller.
The reason for building this is that I think it would be a cheap way to get gapless music using Plex and not spend £100's on a Network Music Player.
Any thoughts and suggestions welcome.
Rgds
Jules
#2
Simply not possible. You can only have one or the other.
And btw. completely wrong forum.
#3
Thank you for your reply.
Why is it the wrong forum…I was looking to install Plex on a device that is supported by Plex.
#4
Because your question has nothing todo with the Plex Media Player, in which section you posted.
It would have suited better here https://forums.plex.tv/categories/pms-raspberry-pi or here https://forums.plex.tv/categories/rasplex
And no, the pi is not supported by Plex.
