Refreshing metadata for existing show takes too long
For some unknown reason today my server is taking too long to refresh metadata for my items. It usually takes a few milliseconds to refresh some items but today it’s taking minutes. Do not know whats going on.
I will provide logs that will show how an existing show on the library ''The Offer" of 3 episodes took minutes to finish its refresh.
Plex Media Server logs.txt (707.0 KB)
It took 8ms according to your log
May 10, 2022 12:09:50.008 [0x7f6921d0db38] DEBUG - Refreshing metadata for 'The Offer' (agent: tv.plex.agents.series)
May 10, 2022 12:09:50.008 [0x7f6921d0db38] DEBUG - MetadataAgentPostProcessor: adding id 86770 to refresh queue (0 items in queue)
May 10, 2022 12:09:50.010 [0x7f69227f2b38] DEBUG - Completed: [172.18.0.15:57728] 200 PUT /library/metadata/86770/refresh (7 live) GZIP 10ms 542 bytes
May 10, 2022 12:09:50.020 [0x7f692238db38] DEBUG - Activity: registered new activity e7b8712c-c917-4441-8dad-15a5d72fefc8 - "Updating Metadata"
May 10, 2022 12:09:50.301 [0x7f692238db38] DEBUG - [JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/994f4ee-4285-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Media Scanner" --match --type 2 --log-file-suffix " Matcher" --item 86770 --match-tag-mode=all
May 10, 2022 12:09:50.302 [0x7f692238db38] DEBUG - [JobRunner] Jobs: Starting child process with pid 621
May 10, 2022 12:09:50.408 [0x7f692238db38] DEBUG - Killing job.
May 10, 2022 12:09:50.408 [0x7f692238db38] DEBUG - Signalling job ID 621 with 9
May 10, 2022 12:09:50.408 [0x7f6924277b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Media Scanner' exit code for process 621 is 0 (success)
May 10, 2022 12:09:50.416 [0x7f692238db38] DEBUG - Extras: 4 existing extras.
May 10, 2022 12:09:50.416 [0x7f692238db38] DEBUG - Extras: Checked extra 'The Offer' and found matched: 1 Media matched: 1
May 10, 2022 12:09:50.417 [0x7f692238db38] DEBUG - Extras: Checked extra 'The Offer (Teaser)' and found matched: 1 Media matched: 1
May 10, 2022 12:09:50.417 [0x7f692238db38] DEBUG - Extras: Checked extra 'The Offer: Now Streaming' and found matched: 1 Media matched: 1
May 10, 2022 12:09:50.417 [0x7f692238db38] DEBUG - Extras: Checked extra 'The Offer: Directing The Untold Story Behind The Godfather' and found matched: 1 Media matched: 1
May 10, 2022 12:09:50.417 [0x7f692238db38] DEBUG - Loaded metadata for The Offer (ID 86770) in 8ms
May 10, 2022 12:09:50.417 [0x7f692238db38] DEBUG - Done with metadata update for 86770
thanks for taking the time to look into it.
weird. why is my notification on the web ui on the top right reloading for a few minutes?
That I sadly can’t answer
