[REL] ExportTools
#1
This is the official thread for
ExportTools
GitHub issues Download of latest releaseDownload total
About
What this little app/channel can do, is simply to export your library sections into csv or xlsx files, allowing you to open up the exported files in like Excel or siml. afterwards.
It also can export posters, in the size you decide
Note: If running PMS on Windows, and exporting into xlsx format, you must be running a version above PMS V1.3! And if not, use csv output format until upgraded
Currently exports Movie, TV-Show, Audio, Photo sections as well as playlists
Do note, that when doing so, to set the encoding to UTF-8 in excel, if exporting to csv.
This plug-in will always be considered “a work in progress”, and will change rapidly, if devs get an idea, or you guy’s suggest something, so fire away.
Manual
The manual was kindly provided by @trumpy81
To see the manual, go here
And please read above, before posting a question!
Install
To install, you have two options:
1 Unsupported Appstore (WebTools) (Easy way)
2 Manual
SourceCode
To get the SourceCode, contribute, or raise an incident, go here
Changelog
To see the changelog, go here
Note2:
This plugin is the replacement of Plex2CSV!
If Plex2CSV is currently installed, please remove it, since it’s discontinued, and everything Plex2CSV could do, this tool can as well, and a lot more!
And do report back both good and bad
/Tommy
Can you Export or Print (PDF) a List of Library Contents
Search library by filename
Wie kann ich die Plex Daten kontrollieren nach Ausfall einer HDD?
Rebuild Plex Library
#2
Also note, that Plex2CSV Repo will be removed soon
#3
Great idea, here are some improvement suggestions:
1) Music - would it be possible to add genre ?
2) Film / series - would it be possible to add codec & encoding parameters used in each track ?
#4
I don't get it? What's the point of this? I mean, it looks dope, but what are you using the csv or xlsx files for?
#5
@moody_blue :
1) Music is called Audio, and already there ;-)
2) It's in level 6
/T
#6
@"seanvree@hotmail.com"
Ever wanted:
* List of all movies with DTS?
* List of movies in a low resolution?
* List of what subtitles you have for a movie?
* List of movies missing index (Bif file)?
* List of.........
List of everything ;-)
#7
Ever wanted:
* List of.........
No, I haven't actually. I mean, I'm trying to understand what this would be useful for?! I mean, what are YOU guys using it for?
#8
Dear dane22 et al,
this is fantastic, will give it a try tomorrow... Having "Audio" makes me think of an "old" idea that I have.
When adding a Music Premium library of my Music collection, I learned that my MP3 tags were simply a mess.
And so was my Music Premium library.
Then I did what seemed to me was a good idea... I fixed everything within Plex, editing A LOT of things, matching every artitst, and every Album.
So, right now, my Plex Music Premium library is the only good source of data that I have since I did not edit the MP3 tags.
Here's my idea for your ExportTools... Use ExportTools to "Export to mp3 tags" :)
All the data is already there including Album and/or Artist covers, etc...
Just use it to tag the files. That would be heaven...
I know that this cannot be done without knowing more about the platform, but how about having a Special Output Format that sets headers and fields correctly already for use with external MP3 Editors like in...
https://forums.mp3tag.de/index.php?showtopic=19225
On the other hand, having an MP3 tagging mechanism that works by Scripting it under Windows/MacOS and QNAP NAS would be a start ;)
What do you think of it?
#9
I don't use it, since the dev can't be trusted :))
And here's what one user used it for, under it's previous name:
mc-guinness.co.uk/blog/20160303/extract-your-plex-movies-or-shows-to-text-file/
/T
#10
Uhh, yeah, I was actually thinking how I could publish this all sexy like to my webserver.
This is dope:
https://github.com/Dachande663/Plex-Export
#11
Seem to be having issues exporting, sure it's something simple but have not spotted any chance you could take a quick look at the log file pls ?
#12
@tylordurton
This is indeed scary, and is caused by a flaw in the framework for Windows, that was supposed to be fixed in V1.3 and above.
For now, sadly all I can suggest is that you select csv as the output format in the prefs of ExportTools, and I'll ask Plex to look into this
Sorry
/T
#13
Thanks for checking and the heads up, looks like it works with CSV so good for now :-)
#14
OP and Github readme changed to reflect this :-(
#15
com.plexapp.plugins.ExportTools.log
http://pastebin.com/raw/49xMbQFF
#16
@paradoxhub
Log says:
OSError: [Errno 13] Permission denied: '/mnt/Media/Movies/ExportTools'
So you need to fix your Linux permissions, so the Plex user has access to that directory
/T
#17
Thanks for the quick response. My Plex installation is located within a FreeNAS 'jail', I can't figure out how to modify the users of the jail only the FreeNAS server users itself but it seems the plugin uses some user within the jail, anyone know how I can do this?
#18
Not me....
The channel runs as the user PMS runs under, so sadly you'll have to go and ask in the server forum, where I suspect more FreeNAS people hangs out.
Sorry
/T
#19
Are there plans to embed the pictures into the excel spreadsheet or create an html file like the Plex Export program? I tried using that program and can't seem to get it working but the output file it creates looks pretty sweet.
This is dope:
#20
No plans for that
