[REL] LazyMan
#1
~~This is a fork of nomego's Lazyman.bundle that adds support for MLB streams now that it was added in the LazyMan app.~~
Now that nomega has merged my PR for MLB support, I am changing the UAS link to point to his repo: https://github.com/nomego/Lazyman.bundle
View NHL and MLB live and archived games, recaps, condensed games, and highlights.
It appears not to support live games on Apple devices at this time. See a workaround here.
#2
Am I missing where your link is? I only see the two (nomega's non-mlb version, and the app itself)
#3
Yep, looks like the link is missing :) @unclenoriega's fork is this one: https://github.com/unclenoriega/Lazyman.bundle
#4
Ha, whoops. Yep, that's the right link. I don't seem to have the ability to edit my post
Edit: I can now. Fixed.
#5
This is not working for me, whatsoever. No live streams, no archived streams. Not working for desktop or mobile.
#6
Everything seems to be working for me. Do you have the latest version?
#7
I have this set up on my PMS and when i try to open any NHL full games the client just spins however i can view the recaps and the condensed games fine. I am running my PMS on a HP Micro server and the client is an Nvidia shield TV.
#8
Same as @argcan here, running plex on freenas and unable to stream from any client (tried xbox one, web client, and android app) except web desktop app.
#9
Same here, Plex on FreeNAS. Recaps work fine but everything else fails using the web browser and android client so far.
An error occurred trying to play this item.
shaka1001 (Network)
Is the error in browser.
#10
For the shaka1001 (Network) error, make sure you have the updated playback.svcs.mlb.com domain in your hosts file.
As for the issues streaming to non–web player clients, I’m not sure. If your client has a setting for forcing transcoding or not, try toggling it.
As of right now, MLB live games, MLB recaps, amd NHL live games (but not recaps) are working for me in the web client. Also, if you are trying to watch MLB games, make sure there is actually a video stream available. Many spring training games may have audio-only or no streams.
#11
Added to hosts but same error with NHL stream using the web client. Have already attempted direct play options changed on and off. MLB does the same thing.
Also attempted an update to force to the latest version.
Oddly enough recaps work just fine they pop up very quickly and play on any device.
The error in my FreeNAS is “pid 71032 (Plex Transcoder), uid 972: exited on signal 4” and this pops up whenever a stream fails to start. Which should indicate an illegal instruction. https://www.freebsd.org/cgi/man.cgi?query=signal&sektion=3&manpath=freebsd-release-ports
Was able to pull some logs and seeing a lot of “warning” statements below is a snippet of what a stream start seems to look like.
2018-03-12 11:19:33,556 (802018300) : DEBUG (networking:166) - Requesting ‘http://powersports.ml/m3u8/2018-03-11/58553403l3c
2018-03-12 11:19:34,553 (802018300) : DEBUG (networking:166) - Requesting ‘http://hlslive-l3c.med2.med.nhl.com/token=exp=1520923942~id=nhlGatewayId:3091833~data=58553403~hash=c3b0dbe252779522b6227b48e5d0d093dd627c0c/ls03/nhl/2018/03/12/NHL_GAME_VIDEO_VANARI_M2_HOME_20180312_1520541556633/master_wired60.m3u8
2018-03-12 11:19:34,977 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,978 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,979 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,980 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,981 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,982 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function PlayStream at 0x8083ce410>
2018-03-12 11:19:34,983 (802018300) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function StreamMetadata at 0x8083ce230>
I am going to search through some other logs and see if I can track something down but I am more of a hardware guy than software.
#12
Found this in corresponding plex logs
Mar 12, 2018 11:19:33.551 [0x80b73c100] DEBUG - [com.plexapp.plugins.lazyman] Sending command over HTTP (GET): /video/lazyman/feeds?date=2018-03-11&game_id=2017021062&sport=nhl
Mar 12, 2018 11:19:33.551 [0x80b73c100] DEBUG - HTTP requesting GET http://127.0.0.1:44902/video/lazyman/feeds?date=2018-03-11&game_id=2017021062&sport=nhl
Mar 12, 2018 11:19:35.163 [0x80ab00900] DEBUG - handleStreamRead code 2: End of file
#13
And I may have found an answer but who knows since it seems to be hit and miss bouncing from a FreeBSD based server to a web client should work if it works on other plex based servers to a web client.
https://support.plex.tv/articles/201161467-why-can-i-not-get-a-live-stream-to-play-on-plex/
#14
I have the same problem with Plex on FreeNAS. Were you able to find a solution ?
#15
NHL Recaps work. No MLB games work at all. No errors, PMS just spins forever.
