[REL] SpankBang, 18+ Channel
#1
SpankBang
Note: This is an Adult channel
This plugin creates a new channel within Plex Media Server (PMS) to view content from spankbang.com. It is currently under development and as such, should be considered alpha software and potentially unstable.
Note: The author of this plugin has no affiliation with the spankbang.com site nor the owners of the content that they host.
Features
  • Watch Free Adult Videos (quality ranges from 240p to 1080p)
  • Custom Bookmarks
  • Video Search
  • Update from within channel
How To Install
  • Install via WebTools UASv2 or follow manual directions below.
  • Download the latest release and install it by following the Plex instructions or the instructions below.
    • Unzip and rename the folder to SpankBang.bundle
    • Copy SpankBang.bundle into the PMS Plug-ins directory
    • Restart PMS
Source code: https://github.com/Nosinden/SpankBang.bundle
ChangeLog: https://github.com/Nosinden/SpankBang.bundle/blob/master/Changelog.md#changelog
#2
SpankBang site changed (aka channel broken), will start working on a fix.
#3
Version 1.0.4
02/07/2016
Note: PMS Restart required for v1.0.4
With this update, the Channel should work again.
  • Adapted to site changes
  • Added DumbTools for Dumb clients
Source: https://github.com/Nosinden/SpankBang.bundle
#4
Sorry the above release was a little too soon. Forgot to check categories section, and I see it is having issues. Will fix and push a new release.
#5
Version 1.0.5
02/07/2016
Note: PMS Restart required for v1.0.5
Sorry about the "pre" release above. Everything should be fixed for now.
  • Fixed summary, genres, and Categories
  • Fixed video format error for low resolution videos
#6
Version 1.0.6
02/08/2016
Note: PMS Restart required for v1.0.6
Wait what!? Another release? Sorry but found a bug in the Service code. v1.0.6 should fully work now.
  • Fixed title error in ServiceCode
#7
Hm, for some reason I cannot seem to get any sound out on this one. Works fine on the other adult channels that I have tested, just not here. Any tips?
#8
Version 1.0.7
03/14/2016
Site changed how categories were listed. Also added new message handler for Plex Home Theater (PHT) and OpenPHT.
  • Fixed error in Categories
  • Added new message handler, works with PHT and OpenPHT
ChangeLog: https://github.com/Nosinden/HanimeTV.bundle/blob/master/Changelog.md#changelog
#9
Sorry no. The site host there own videos, and as such their videos seem to have issues like this sometimes. Sorry I don't have a better answer at the moment.
Only other thought is it might be a compatibility issue with the source video and the metadata I assigning it. You can try disabling Direct Play (within a client) and see if the audio works once transcoded through your PMS.
I'll take some time to look into this further, but unless I can reproduce the error on my end, it will be hard to pinpoint the cause.
#10
When you install it restart computer. After restarting works fine. The same thing is with Cliphunter
#11
I've tried restarting the computer and I still get no response from the channel - I can go through the categories, but when I get to the point of listing videos, I get "This channel is not responding".
#12
It is not working here either and the same message appears. It just stopped a few days ago. Must be a change in the web site.
#13
@Nosinden. hi im having same problem,getting the "this channel is not responding" message,any chance of a fix,and thanks again for all your great work.
#14
Thanks, I'll check it out today. Hopefully will be a quick fix.
#15
It was a simple fix, had to do with a change in where the video duration was located.
Holding off on pushing the fix, because wanted to update the bookmarks to be similar to ClipHunter as-well-as add an option to bookmark adult stars from the video page. This will add a new adult star menu beside the similar video list, allowing one to bookmark the star and/or view videos they are in. Unfortunately the Spankbang site does not list all of it's adult stars, so I cannot add a list for them, hence the added utility of bookmarking stars.
#16
Ugh, GitHub's bot just flagged my account as not human, so had to put in a service requests to reinstate my profile. So frustrating, in the meantime my GitHub profile/repos are hidden from public until they deem me as human.
Edit: Well that was fast, profile is public again.
#17
Version 1.0.8
05/27/2016
Note: PMS Restart is recommended for v1.0.8 update
Everything should work now. Added the ability to bookmark Adult Stars, and view the video thumbs. Upon updating the bookmarks will auto-correct themselves for compatibility with the new style.
  • Fixed ServiceCode category error, was pulling more info other than categories
  • Updated Bookmarks to include new Adult Star section
  • Added new Video thumbs, Adult Star in video section (if info available), and ability to bookmark Adult Stars
#18
Version 1.0.9
07/03/2016
Site now host 1080p resolution.
  • Updated resolution dictionary within ServiceCode
  • Corrected bitrates for hosted content
#19
Version 1.0.10
08/13/2016
Site changed how resolutions are listed.
  • ServiceCode - updated resolution dictionary pull#3 (credit @"NotVinny")
  • ServiceCode - cleaned/simplified PlayVideo code
#20
Version 1.1.0
08/26/2016
Updated icons/art and UI to match main site. Added new Adult star section.
  • New icons/art
  • New Adult star section
  • Updated UI to match main site
  • Fixed pagination logic pull#4 (credit @NotVinny)
  • DumbTools - added Xbox One & Apple TV v4
Edit: Fixed issue outlined in Comment_1241875 and re-released same version.
