[RELEASE] Aeon Nox 5.4.0
aeon-nox
#1
The Aeon Nox Team is pleased to announce that Aeon Nox 5.4.0 is out!
Please note that Aeon Nox 5.4.0 requires OpenPHT 1.8.0 (also out today). After upgrading OpenPHT, Aeon Nox 5.4.0 can be updated (or installed fresh) from OpenPHT. If you want to manually update, the downloadable version is here: https://github.com/magnumdoomguy/skin.aeon.nox.5/releases/tag/v5.4.0
General:
  • Per view toggle SD/HD flags
  • Per view blur background setting
  • Per view toggle Topbar setting
  • Added "play all" and "shuffle all" to Music recently added filter.
  • Search, Settings, and Skin Settings overhaul
  • Updated studio flags
  • Updated translations, including new Swedish translation. Thanks hakgle!
  • Rasplex specific tweaks and optimizations
  • Numerous small tweaks, optimizations and bug fixes
Home Window:
  • Home menu customizer: fine tuned customization of the home main menu and the submenus. Each main menu item has a unique submenu, and the submenu items can be populated however you wish
  • Home menu quick filters: Filters directly on the home menu for each library type with filters for genres, collections, actors, etc.
  • Extensive collection of genre icons for browsing by genre, country flags for browsing by country, and actor images populated by PMS for browsing by actor.
Shift View:
  • Added infopanel
  • Added "small posters" option
  • Added "flat" style
  • Adaptive labels (automatically change based on the media type and the filter used)
  • Added Shift to Home Videos (Portrait mode only)
  • Added Shift to Shared Content
TriPanel View:
  • Added "flipped" style
  • Appearance tweaks
  • Adaptive labels
  • Added TriPanel to Home Videos (Portrait mode only)
  • Adaptive plot size (size of plot summary adapts to amount of metadata PMS is able to provide for the media)
FanartList:
  • Adaptive labels
  • Added FanartList to Watch Later
  • Added FanartList to Home Videos-
ShowCase View:
  • Added "flat" style to ShowCase
  • Added ShowCase to Shared Content
  • Added ShowCase to Photos
  • Added ShowCase to Home Videos (Portrait mode only)
Landscape View:
  • Adaptive Labels
  • Added "flat" style to Landscape
  • Added Landscape to Watch Later
InfoWall View:
  • Enhanced focus animation
  • Added InfoWall to Home Videos (Portrait mode only)
Channels:
  • Enhanced display of Channels
  • Removed viewtypes other than List from Channels (more will be added later, but the ones removed were behaving pretty badly)
Thanks to @kwiboo for the awesome OpenPHT 1.8.0 release (and putting up with me), @"daniel.cull" for his diligent testing and constructive feedback, @aeronnl for the Dutch translation, @danichispa for the Spanish translation, mikesilvo164 for all the awesome Aeon Nox Silvo mods that were used in this update.
#2
great work guys thanks!!!
#3
Awesome update, thanks @MagnumDoomguy
#4
I can’t wait to test both this and the new OpenPHT!
#5
It’s… so… beautiful. Thank you.
#6
Is it possible to move “Power” and “System” to the submenu in home windows?
#7
It is via the new Home Menu Customizer.
#8
Can you explain it in detail? I have seen the Home Menu Customizer but couldn´t find a way to move the items to submenu, just disable/enable. I won´t disable “System” :wink:
#9
Found it. Thanks for the great update.
#10
@MagnumDoomguy Thanks for this update, and thanks for the work you do on OPHT. Excellent updates here :slight_smile:
#11
Thanks to @kwiboo for the awesome OpenPHT 1.8.0 release (and putting up with me), @“daniel.cull” for his diligent testing and constructive feedback, @aeronnl for the Dutch translation, @danichispa for the Spanish translation, mikesilvo164 for all the awesome Aeon Nox Silvo mods that were used in this update.
It’s way legit, thanks dude
#12
I’m brand new to this part of Plex: how do I access the settings to add this skin?
#13
Aeon Nox is for the OpenPHT Plex client. Download and install OpenPHT from here: https://forums.plex.tv/discussion/264209/release-openpht-1-8-0
Once OpenPHT is installed Aeon Nox can be downloaded and installed directly from the OpenPHT client itself. Preferences --> Appearance
#14
Thanks - I got it set up. So if I’m understanding correctly, this is totally separate from the Roku channel?
#15
Correct, OpenPHT is completely separate from the Roku channel. OpenPHT is available on a fair bit of different hardware but not everything. Roku apps have their own programming language so porting OpenPHT to the Roku platform is unlikely to happen (would be a massive amount of work, more than the rest of the project combined, and would basically grind all OpenPHT development – particularly with our small team – to a total halt). OpenPHT is a great client though – and runs great even on some very cheap hardware. Definitely my first choice of clients, but obviously I’m biased. :slight_smile:
#16
Any way to get back backgrounds for specific libraries? I have a library for my daughter’s shows and would like that to have a different background than my main tv shows background. I also have movies separated into kids movies and my own. If not is it be possible to restrict the selection of “Fan art” only to selections from that particular library?
#17
You mean the homescreen background when you select a certain library? Because in that case I think it already takes the background from the artworks of that specific library.
#18
It currently pulls artwork from whole library
#19
Sure, but you said you have a library for your daughter’s show, I get that you have another library for your own shows. In this case every section should take the artwork from each library. Or did you mean from the whole server media?
#20
It used to work that way. Now the art is grouped by movie, tv show, music, and photo. I have 2 Movie libraries, my daughters and mine. the artwork is now from all movies.
