# \[RELEASE\] RasPlex 1.0.2
**URL:** <https://forums.plex.tv/t/release-rasplex-1-0-2/133577>\
**Category:** Apps & Creations\
**Created:** [January 31, 2016, 10:53am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577 "2016-01-31T10:53:09Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![Kwiboo](https://avatars.discourse-cdn.com/v4/letter/k/f14d63/32.png) [@Kwiboo](https://forums.plex.tv/u/Kwiboo)\
**Post date:** [January 31, 2016, 10:53am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/1 "2016-01-31T10:53:09Z")
</div>
Today we announce the release of RasPlex 1.0.2 and [OpenPHT 1.5.1](https://forums.plex.tv/discussion/205162/release-openpht-1-5-1/p1 "OpenPHT 1.5.1")
**New**
- Added Skin option to show shutdown/restart for managed users
- Added Preferences option to show watched items in recently added fanout
- Added go to show/season to context menu for episodes
- Added support for shared channels for managed users (need to enable in PMS/Users)
- Support for libdcadec to decode DTS-HD MA to 8 channel LPCM (disable DTS capable receiver and enable DTS decode in Preferences)
- Updated default CEC remote keymap for Guide/Info and color buttons
- Updated Hyperion to latest
- Base system upgraded to OpenELEC 6.0.1
- Updated Linux kernel to 4.1.16 and latest RPi firmware
**Fixes**
- Rendering improvements to speed up navigation and playback
- Show correct artist for tracks with other artists i.e. Various Artists tracks
- Update now playing visualization showing correct track artist and artist/album/track order
- Show all filter and sort options for home movies
- Rotten Tomatoes was still showing for movies that did not have correct data from PMS if you have rated the movie
- Fixed a Plex Home user switching bug involving previous menu action
- Ensures [plex.tv](http://plex.tv) sign in pin is no longer truncated to … if it is too wide
- All built-in visualization except now playing is removed, they did not work or caused crashes
- dca-ma, theora, vp6, vp8 and vp6f are now known codecs
**Downloads**
- RasPlex 1.0.2: [https://github.com/RasPlex/RasPlex/releases/tag/1.0.2](https://github.com/RasPlex/RasPlex/releases/tag/1.0.2)
- OpenPHT 1.5.1: [https://github.com/RasPlex/OpenPHT/releases/tag/v1.5.1.508-67218541](https://github.com/RasPlex/OpenPHT/releases/tag/v1.5.1.508-67218541)
**Bugs?**
Please report any bugs to [http://tiny.cc/rasplex-bugs](http://tiny.cc/rasplex-bugs)
**Author:** ![KnightOrc](https://sea1.discourse-cdn.com/plex/user_avatar/forums.plex.tv/knightorc/32/4373_2.png) [@KnightOrc](https://forums.plex.tv/u/KnightOrc)\
**Post date:** [January 31, 2016, 11:35am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/2 "2016-01-31T11:35:01Z")
</div>
1.0.1 has moved to the stable channel, without changing anything you can/will upgrade to 1.0.1.
1.0.2 is in the pre-release channel for a week or two, if you want to upgrade to it change which upgrade channel you are using to pre-release.
**Author:** ![mastoul](https://avatars.discourse-cdn.com/v4/letter/m/ecd19e/32.png) [@mastoul](https://forums.plex.tv/u/mastoul)\
**Post date:** [January 31, 2016, 12:08pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/3 "2016-01-31T12:08:33Z")
</div>
Hungs to download 100% and even if I restart the rpi2 cannot update
**Post date:** [January 31, 2016, 12:16pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/4 "2016-01-31T12:16:21Z")
</div>
Checksums was wrong in release notes, please try again after a restart.
**Post date:** [January 31, 2016, 12:37pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/5 "2016-01-31T12:37:38Z")
</div>
Ok now it works
**Author:** ![damien.thg](https://sea1.discourse-cdn.com/plex/user_avatar/forums.plex.tv/damien.thg/32/12753_2.png) [@damien.thg](https://forums.plex.tv/u/damien.thg)\
**Post date:** [January 31, 2016, 8:09pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/6 "2016-01-31T20:09:54Z")
</div>
Once again, many thanks to the rasplex team for this awesome job.
**Author:** ![Jacob\_Baek](https://avatars.discourse-cdn.com/v4/letter/j/9de053/32.png) [@Jacob\_Baek](https://forums.plex.tv/u/Jacob_Baek)\
**Post date:** [February 1, 2016, 6:56pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/7 "2016-02-01T18:56:16Z")
</div>
thank you for this update! i love rasplex!
**Post date:** [February 1, 2016, 10:25pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/8 "2016-02-01T22:25:03Z")
</div>
If I well understand, we can not do passthroug to the amplifier, it’s rasplex who decodes dts HD?
You could bring us details ?
**Post date:** [February 2, 2016, 5:43pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/9 "2016-02-02T17:43:39Z")
</div>
If you want PCM 8 channel output (decoded 7.1) instead of passthrough (which can only do up to 5.1), you follow the advice above, disable passthrough, enable DTS decode in preferences. Then all DTS will be decoded by the RPi and sent to the amp as PCM.
**Author:** ![Pikoasis](https://sea1.discourse-cdn.com/plex/user_avatar/forums.plex.tv/pikoasis/32/11400_2.png) [@Pikoasis](https://forums.plex.tv/u/Pikoasis)\
**Post date:** [February 5, 2016, 8:19am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/10 "2016-02-05T08:19:09Z")
</div>
Hi ! Thanks a lot for your job !
But what’s the difference between Rasplex and OpenPHT ?
Thanks !
**Author:** ![system](https://global.discourse-cdn.com/plex/original/3X/2/a/2acb9765406f63293d357b4ec509ec39aa28f2ad.png) [@system](https://forums.plex.tv/u/system)\
**Post date:** [February 5, 2016, 8:36am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/11 "2016-02-05T08:36:19Z")
</div>
With the last release of OpenPHT, the only difference is that OpenPHT can be installed on Windows/OSX machines, Rasplex has it’s own underlying OS based on OpenELEC which is Linux and only runs on the RPi. Rasplex had more features than OpenPHT but they are now in sync and will continue to be going forward.
Regards
**Author:** ![incognitoxic](https://sea1.discourse-cdn.com/plex/user_avatar/forums.plex.tv/incognitoxic/32/8395_2.png) [@incognitoxic](https://forums.plex.tv/u/incognitoxic)\
**Post date:** [February 5, 2016, 3:42pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/12 "2016-02-05T15:42:55Z")
</div>
Hello! Thanks you for your job!
What is the multi-colored square in the upper right corner, and how to remove it :). Thanks.
**Author:** ![Valdhor](https://avatars.discourse-cdn.com/v4/letter/v/ebca7d/32.png) [@Valdhor](https://forums.plex.tv/u/Valdhor)\
**Post date:** [February 5, 2016, 4:01pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/13 "2016-02-05T16:01:30Z")
</div>
Either your power supply does not provide enough current (2A recommended) or your power supply cable is not providing enough current.
There are many threads here regarding the problem.
**Post date:** [February 5, 2016, 11:10pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/14 "2016-02-05T23:10:46Z")
</div>
Thank you so much! 😃
**Author:** ![cossack1977](https://avatars.discourse-cdn.com/v4/letter/c/9e8a1a/32.png) [@cossack1977](https://forums.plex.tv/u/cossack1977)\
**Post date:** [February 7, 2016, 5:15am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/15 "2016-02-07T05:15:00Z")
</div>
Thanks guys for the update.
Can you confirm if this will now allow Hifiberry(Digi+) audio for movies or is it still only for music.
I have read that this release is the latest Linux Kernel and Pi firmware but that doesn’t answer if this will now work for movies.
Thanks in advance and thanks for the hard work as always.
**Post date:** [February 7, 2016, 8:03am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/16 "2016-02-07T08:03:19Z")
</div>
Still only music at the moment.
Regards
**Post date:** [February 7, 2016, 8:55am UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/17 "2016-02-07T08:55:42Z")
</div>
The lack of support for movies is not related to the kernel or RPi firmware, it requires a much newer player to be used in RasPlex, but due to the massive amount of tweaking in the current one to make it perform it isn’t as simple as replacing it with the new version.
Will be done when it is done.
**Author:** ![CaptainFred](https://avatars.discourse-cdn.com/v4/letter/c/13edae/32.png) [@CaptainFred](https://forums.plex.tv/u/CaptainFred)\
**Post date:** [February 11, 2016, 10:35pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/18 "2016-02-11T22:35:10Z")
</div>
I have auto update turned on and I checked for updates manually but it said my current version 1.0.1 was up to date… do I need to update manually? and if so how?
**Post date:** [February 11, 2016, 11:05pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/19 "2016-02-11T23:05:15Z")
</div>
Change to Pre-release channel, see the second post, hmmm.
**Author:** ![treboR2Robert](https://avatars.discourse-cdn.com/v4/letter/t/a4c791/32.png) [@treboR2Robert](https://forums.plex.tv/u/treboR2Robert)\
**Post date:** [February 11, 2016, 11:36pm UTC](https://forums.plex.tv/t/release-rasplex-1-0-2/133577/20 "2016-02-11T23:36:37Z")
</div>
This release seems to have “somewhat” fixed the horrible issue with FF and RW that has plagued every release since 0.6.0.
Wooooo =D\>
Keep up the EXCELLENT work guys and gals ^:)^
[Next page](https://forums.plex.tv/t/release-rasplex-1-0-2/133577.md?page=2)
