Check the client quality settings and the server remote access “limit remote stream bitrate”
May 21, 2026 14:14:14.003 [547131236576] DEBUG - [Req#ebfded/Transcode] We're going to try to auto-select an audio stream for account 1.
May 21, 2026 14:14:14.003 [547131236576] DEBUG - [Req#ebfded/Transcode] Selecting best audio stream for part ID 53986 (language: en)
May 21, 2026 14:14:14.003 [547131236576] DEBUG - [Req#ebfded/Transcode] We're going to try to auto-select a subtitle for account 1.
May 21, 2026 14:14:14.003 [547131236576] DEBUG - [Req#ebfded/Transcode] Audio Stream: 103634, Subtitle Stream: -1
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Selected protocol hls; container: mkv
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: analyzing media item 53983
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): Direct Play is disabled
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): media must be transcoded in order to use the hls protocol
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no direct play video profile exists for http/mp4/h264
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no direct play video profile exists for http/mp4/h264/ac3
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): Direct Streaming is disabled, so video stream will be transcoded
May 21, 2026 14:14:14.030 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no remuxable profile found, so video stream will be transcoded
May 21, 2026 14:14:14.031 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
May 21, 2026 14:14:14.031 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): selected media 0 / 53983
May 21, 2026 14:14:14.031 [547131236576] DEBUG - [Req#ebfded/Transcode] Streaming Resource: Calculated bandwidth of 7433kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
May 21, 2026 14:14:14.031 [547131236576] DEBUG - [Req#ebfded/Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
May 21, 2026 14:14:14.063 [547131236576] DEBUG - [Req#ebfded/Transcode] Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 1024x426, audio channels to 6, quality to 8, disable audio DS as 640kbps is > the 327kbps available
May 21, 2026 14:14:14.064 [547131236576] DEBUG - [Req#ebfded/Transcode] Clipped max bitrate to 1555Kbps based on client-requested limit
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Selected protocol hls; container: mkv
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: analyzing media item 53983
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): Direct Play is disabled
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): media must be transcoded in order to use the hls protocol
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no direct play video profile exists for http/mp4/h264
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no direct play video profile exists for http/mp4/h264/ac3
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): Direct Streaming is disabled, so video stream will be transcoded
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): no remuxable profile found, so video stream will be transcoded
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] Clipped max bitrate to 1555Kbps based on client-requested limit
May 21, 2026 14:14:14.065 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
May 21, 2026 14:14:14.066 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
May 21, 2026 14:14:14.066 [547131236576] DEBUG - [Req#ebfded/Transcode] MDE: Silver Linings Playbook (2012): selected media 0 / 53983
May 21, 2026 14:14:14.067 [547131236576] DEBUG - [Req#ebfded/Transcode] Streaming Resource: Reached Decision id=28244 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4010,This item cannot be played at this time. The server has reached its configured limit for maximum simultaneous video transcodes.)
May 21, 2026 14:14:14.069 [547985686752] DEBUG - Completed: [174.201.182.231:1187] 200 GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F28244&session=9e2ad18b-154c-42d0-9ddb-da3a533427dd&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=0&videoQuality=60&videoResolution=1024x720&audioBoost=100&autoAdjustSubtitle=1&boostDialog=0&normalizeLoudness=0&subtitles=none&maxVideoBitrate=2000&location=wan (16 live) #ebfded TLS GZIP 111ms 703 bytes (pipelined: 2
