Remote Access with Eero Mesh Wifi
server-windows
#1
I am having some issues with the remote access for my plex server. It use to connect just fine without any issue, but not it will not connect at all. When I refresh plex, it will enable remote access for about 2 seconds and then shut it off. I have gone through and found that a double NAT is not an issue as my modem does not double down as a router and I have gone through and set up port forwarding for the server and it still does not work.
If it helps, I am running an Eero Mesh Wifi network with two access points and the main hub, along with a Netgear cm400 modem.
I don't know if anyone has dealt with this before, but any help would be awesome.
#2
So looking at this your Netgear cm400 is just a cable modem so no config there.
Did you follow this guide for port forwarding on your eero?
If you go to http://canyouseeme.org/ and change the port to the port you setup for forwarding does it show success?
#3
Yep, that's exactly how I forwarded the port. I just checked with canyouseeme.org and got success.
#4
Well you are 99% there!
I saw this on a different post so try this now -
If you do disable / re-enable remote access or tick/untick manually specify port, there are some timing problems that may give rise to status being incorrect - a reboot after enabling it and manually specifying the port may help. The issue would be arise if there are numerous clicks and in quick succession - best to leave 30 second gap between clicks and if set correctly best not to unset/reset
So get the check box ticked for port specified and make sure its all set right get a reboot for a nice fresh start and make sure.
Also you should be able to browse http://x.x.x.x:32400 from your mobile phone while NOT on your home Wifi where x.x.x.x is the IP that canyouseeme.org reports and get a plex login screen.
#5
Seems to be working now. I did a reboot and it was up, but I had an update for the server. I ran the update and the remote access didn't work again. I went ahead and did a second reboot and it seems to be fine now. I just hope I don't have to continue to reboot after every server update.
Thanks for all your help!!
#6
Nah mine is stable once its setup and not being messed with its happy, I haven't had to mess with that in ages.
#7
I am also seeing problems.
Today it said it only allowed indirect connections.
When I reset the connections on the remote settigns the server is completely offline
#8
I am now having the same issue. I am trying to do the same troubleshooting, but not getting anywhere. It was working fine for a while, but has since stopped all of the sudden.
#9
I had no problems with Plex and Eero up until early September when I moved into a CenturyLink area and ran into doubleNAT issues. I've bridged my Eeros and port forwarded and I still get remote access/indirect connection issues. Not sure if this is due to my CL setup or something else going on like what was reported above.
#10
did you fix your issues? I have CL too and have ruined into the same issue.
@Travillion said:
I had no problems with Plex and Eero up until early September when I moved into a CenturyLink area and ran into doubleNAT issues. I’ve bridged my Eeros and port forwarded and I still get remote access/indirect connection issues. Not sure if this is due to my CL setup or something else going on like what was reported above.
#11
TBH, I’m not sure. It’s working for me now, but it has been unreliable in the past. In my first attempt at port forwarding, I did not setup a static IP for my server (PC), so things broke once my computer reset.
In my latest effort, I setup a static IP, and that alone seems to be working. Strangely enough, things would break when I would try the port forwarding step :confused:
