Remote connection/access not possible,Port 32400 is enabled
Server Version#:4.1590
Player Version#:IOS newest version
I’m having the same issue as many others, it says remote access is fully accessible for seconds, yet I can’t connect to it outside my network also app.plex.tv doesn’t work.
Ignore the flickering remote access status indicator… it’s only listing a green status while testing your remote connection.
Did you already have a look at the related troubleshooting support article?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
There’s also a guide with some more details on how to troubleshoot remote access issues.
https://forums.plex.tv/t/the-basics-of-remote-access-troubleshooting/769517
i’ve read a lot of related articles. seen some YT videos but nothing helped. I have dyndns account, tested too, didnt work! Thinking about a certificate problem maybe? How can i test it? Get a new one? Sorry for bad english, i’m german, thx for reply
The troubleshooting isn’t so much about the outcome… you already know it’s not working. It’s about the output / findings of the individual steps — e.g. is your forwarded public port visible outside your home network?
checked now with little snitch (outgoing FW) , signature should be ok, valid till 2/27, outgoing traffic to Plex is working
canyouseeme.org says everything is ok
You weren’t going crazy, Plex’s back end has been down for a few hours. Just starting to come back up now.
didnt work, solved the Problem now with Tailscale, thx
