Removing Recently Added Movies / TV Shows v 1.32.4.7195
Server Version#: 1.32.4.7195
Player Version#: 4.108.0
Hello, I’ve been digging around for a couple of days now and I can’t seem to find a solid solution for removing the “Recently Added in Movies” and Recently Added TV Shows" from my home screen. I found talk about editing the database, but I’m hoping there’s a more “settings” option than that. Also found an option about adjusting the system clock and doing a library scan but again, seems like this should just be a setting, no? I have combed through all the settings but I’m hoping it’s user error and I’m just missing it. Any thoughts/help is greatly appreciated.
-Jeff
In Settings, select “Libraries” under the “Manage” section.
Hover over the library you want to change, and click on “Manage Recommendations”:
Then you can select which recommendations you want to appear:
You are absolutely my hero! Thank you VERY much. I was in that screen, but I was missing the “Manage Recommendations” option as I hovered over the library on the left. That did the trick. I really appreciate the assistance; I’ve been searching for this for a bit now.
Best,
Jeff
