Roku player get stuck at 99% when trying to play
roku
#1
We have a roku TV that isn't able to play a recorded TV show. The show is recorded with plex but it is recorded using another server on my network. I am able to play the file on the web interface. I converted the file to MP4 and it played. The issue continues, is there anyone else with similar issues? The issue started on Thursday and there was a new version of the Player for roku on Wednesday.
#2
I had the same issue on some HEVC videos
Prior to the update the same files could be forced direct play, and would do so without issue.
#3
There is a bug somewhere in how the new client is interacting with the transcoding process within Plex. OTA (Plex DVR) is recorded as mpeg2 unless you have a real-time transcode being done while recording. (SiliconDust has a HDHomeRun that does this for example)
The only known work around is to transcode the files into a format that has “native” support within your Roku device. Such as h264 level 4.1
Mpeg2 is not a supported format on Roku, so until the bug is fixed, Plex will be unable to transcode it in “real time” for you.
#4
I found that it is a problem with the transcoding. I am able to force the client to direct play and it will work. I read that this was a known issue when they released the client as a stable release. A little disappointing that it will not play recordings that was recorded on the Plex DVR. I hope for a fix soon.
#5
Add me to the list of people with DVR files that won’t play. I’ve found I only have this issue with files recorded from a certain channel for the most part. Roku TV as well.
Here are the file specs:
Video: 480i—H264
Audio: English—AC3 Stereo
Files of this type work fine:
Video: 720p—H264
I have the HDHomeRun Extend, and PMS is running on Windows 10. Perhaps it’s the interlace part?
#6
Video: 480i—H264
Video: 720p—H264
So 480i is breaking even on h264? Try forcing direct play, Roku should be able to play it. I’d suspect Plex is transcoding it to deinterlace the feed.
#7
Actually, the workaround for me was the opposite. I had to disable direct play to get it to work. I had disabled direct stream first, but that did nothing.
Odd… It’s worked since the inception of DVR until this week.
