Roku Plex Ac3 audio sync issues
roku
#1
I just got a new Roku Premeire+ and running plex. aac 5.1 and DTS 5.1 works great on it but whenever i try a ac3 5.1, there is about a 3 sec audio sync issue (sound comes firdst before video). These files works fine on plex for Chromecast and Amazon fire stick.
I tried every possible combinations of direct play / directstream options in the roku plex but nothing fixes the issue. I tried changing the audio options on Roku and some options either did not do anything or gave no audio.
Hdmi plugs directly in my receiver Onkyo TX-NR646. Running the latest Plex Media Server on a laptop supporting a 4th gen i5 processor. It can transcode most of everything I throw at it including multiple HEVC streams.
I love the roku in both video quality and processing speed. I also like how it can play DTS without transcoding it. It's just that I have many files with ac3 audio and this is a major issue. I hope there is a simple work around that does not involve changing the audio format to stereo to force a transcode to stereo. I do not mind forcing a transcode from ac3 to aac but do not know how to do it.
#2
Roku has issues with lips and the sound of the words living in the same zip code.
Here’s hoping Windows 8 for Roku helps - but I have my doubts.
I was watching a program last night (Direct Play, no less) - lips and words got all out of whack - switched to PMP to finish the program and all was well.
The best you can hope for at this time is a ‘backup plan’.
Roku has an index finger buried up a nostril to the second knuckle and they’re diggin’ for gold.
#3
I love the roku in both video quality and processing speed. I also like how it can play DTS without transcoding it. It’s just that I have many files with ac3 audio and this is a major issue. I hope there is a simple work around that does not involve changing the audio format to stereo to force a transcode to stereo. I do not mind forcing a transcode from ac3 to aac but do not know how to do it.
Same issue here, works fine in emby for roku for me though so my guess is the plex app.
#4
I figured it out. It may not be a perminant fix up when it acts up, unplug it for about 10 sec and plug it back it. Everything including ac3 works again for a few days before it get off sync again. Unplug again to temporarily fix issue. Not perfect but I can live with that
#5
Same problem with Roku Ultra. Firmware 8.0.0 build 3138-46.
Unplugging didn’t seem to help.
#6
I have this same problem. Only seems to be a problem with AC3. Happens on my Ultra, Premier, and two Roku3s. Haven’t tried the unplug/replug trick. But if I force a transcode out of AC3, it works perfectly. Come on Roku, fix this!!
