Roku2 issue and workaround
plex-classic-for-roku
#1
The Roku2 has a known issue that results in videos not playing.
Here are some work around binaries.
For Mac replace (or set aside) the binary in ~/Library/Application Support/Plex/Plex Media Server.app/Contents/MacOS with
http://www.plexapp.com/elan/pms-roku2-workaround.zip
For windows, here is the replacement binary. Sorry, I'm not a windows user so I don't know where it goes exactly. Can a knowledgeable windows user please add to the thread with the location?
http://www.plexapp.com/elan/pms-roku2-win32.zip
See original thread for more details.
http://forums.plexapp.com/index.php/topic/28292-roku-2/
Jonny
#2
C:\Program Files\Plex\Plex Media Server in Windows XP
#3
So, still no Linux/Ubuntu fix available?
#4
Under Application Support their was no Plex folder or Plex app. I went ahead and went under applications and did show contents and found the folder archive that way and copied it in their but still no luck for me just starts to load a video and stops. I also coppied the Plex app so it would match up with your file path and of course closed plex and re-opened but no luck. Any ideas this program looks really cool but doesn't work for me at all right now really.
#5
[quote name='jtizzle07' timestamp='1313367704' post='188531']
[/quote]
You are looking in the wrong application support folder. It's the one under your home directory, which is what ~ means, not the one on the root of the drive.
Jonny
#6
[quote name='Jonny Wray' timestamp='1313369890' post='188540']
Jonny
[/quote]
Thanks that worked!
#7
Any updates on a Linux workaround?
#8
There are a lot of Linux builds. Which specific versions are people interested in?
#9
I'm interested in the Ubuntu build... I run x64 if there's a build specific to that, though I think they're all 32-bit builds at the moment.
#10
Don't know if this is in the right thread or not but the fix you had me do is working. But I have noticed that when watching stuff it takes it forever to load then every so often it will do it again. Very annoying because it can take up to a couple of min for it to load. I have the quality set to auto don't know if this makes a difference or not.
#11
[quote name='jtizzle07' timestamp='1313585682' post='189228']
[/quote]
Could you post your setup so folks could try to help? This fix works flawlessly for me, load times are almost instant, playback is smooth. I have a Roku2 connected by ethernet back to a switch. My PMS is running on a Mac Mini C2D running the latest Plex build and the workaround on Snow Leopard.
#12
[quote name='Jonny Wray' timestamp='1313530393' post='189031']
[/quote]
I am also interested in the Ubuntu build
#13
[/quote]
As cfriedberg says, without more details this is impossible to troubleshoot, as there are lots of variables here. Taking a while to load is usually an indicator of transcoding, but a couple of minutes is on the high side.
Have you tried different quality settings to see if it makes a difference, much better way of finding out that me guessing.
What's your set up (PMS platform, wireless, etc), what's the media format you are having issues with, subtitles or not?
Jonny
#14
For many of us, who aren't "geeks", taking the time to give full directions (for example, what is the "binary" file I am looking for) would be most helpful.
[quote name='Jonny Wray' timestamp='1313341102' post='188431']
Jonny
[/quote]
#15
[/quote]
I'd be interested in a fix for the "official" Ubuntu builds from Plex's repo:
deb http://www.plexapp.com/repo lucid main
(straight from my /etc/apt/sources.list)
The current package from that repo is 0.9.3.5ubuntu1
#16
So no ubuntu/linux fix?
#17
Another request for the Ubuntu (11.04, 64 bit) fix.
Thank you for an excellent product.
#18
My first time setting up the PMS, I got this issue of "No Video Playing". However, my issue happens on both the Roku2 and the Roku HD. Once I replaced this binary, the Roku2 works, but not the RokuHD.
Any idea why?
#19
[quote name='Rick D.' timestamp='1314707938' post='192339']
Any idea why?
[/quote]
Are you on wireless? Have you set the quality to 2mb or less?
Jonny
#20
Request work around for Unraid/Slackware version
