Rottentomatoes ratings not displaying
ios
#1
Hello,
I have recently updated to the Plex for iOS 4.0 and I am not seeing any rottentomatoes ratings in my app. My server, running on Mac OS Yosemite, is on version 0.9.12.8. Is there any server-side configuration that needs to be done in order to see these ratings?
Thanks!
Tyler
#2
If your movies aren't displaying ratings from Rotten Tomatoes, simply check you have the Freebase agent enabled and then perform a force-refresh on your movie library.
more info on agents here: https://support.plex.tv/hc/en-us/articles/200241558
#3
Thanks for the quick response! My issue is resolved :)
#4
any guides for setting this and chapter info for iOS up ?? checked freebase agent can't see anything about rotten tomatoes :/ am running latest unraid plexus release, please help!
#5
have fixed, unraid container wasn't updating properly, deleted container re-installed and bingo :)
#6
RT Ratings implementation is very neat! Nevertheless, what I don't like is that they are replacing the regular rating (stars) completely if they exist. So I never see my own ratings again if there are RT entries...
What was the conceptual intention by doing so? And is there a way to see both?
#7
I'm still not having any luck with this - have followed the steps above but still no ratings showing
#8
Are you sure you did a FORCE refresh after enabling the Freebase agent? (not a standard refresh - since that won't look at already-there/metadata-d media).
#9
I can't get the ratings from Rotten Tomatoes to show even with the Freebase agent enabled. I forced a refresh on my library and I still can't see them. Do I have to have The Movie DB dragged below the Freebase agent in the settings?
#10
This new feature is only available with one of the latest releases of Plex Media Server. Are you running the latest release already?
#11
Ya it shows I'm up to date.
#12
Yep, did that a number of times - the one with the warning it might take a long time
#13
Yep, I have the same problem.
Rotten Tomatoes ratings not showing in new iOS app, despite doing a proper force refresh of my library (several times now). I have also restarted the Plex Server, and fully closed and relaunched the iOS app (as well as deleting the app cache a few times). Still not showing.
Plex Media Server version 0.9.12.8 running on OS X Yosemite, latest iOS app v4, Freebase agent enabled in settings.
[edit] Also just tried uninstalling iOS app, restarting phone and reinstalling app - still not showing [/edit]
#14
I am also having this issue. Plex server is up-to-date and running Windows 7 64bit OS. iOS apps are updated as well
#15
Does the fact that this topic is flagged as 'answered' mean that no one will help? Anyone fancy joining me on a new thread?
#16
Here is one still not answered. Including "wrong RT ratings" and "not showing RT ratings at all":
https://forums.plex.tv/discussion/comment/993360#Comment_993360
#17
OK, I disabled the RT agent I'd installed, moved Freebase up to 2nd choice (under local media assets) and did another force refresh and that has worked
#18
I'm getting RT ratings for maybe 60% of my movies, and the rest keep the star rating even after refreshing multiple times. Not sure why some do and others don't - for instance The Amazing Spiderman (2012) keeps the star rating, while The Amazing Spiderman 2 (2014) updates with the RT rating. The ones I've checked have accurate RT ratings.
#19
I’ve been trying to find an answer on the forums on why my Rotten Tomato ratings aren’t being displayed either. I made sure freebase and rotten tomatoes are enabled and did a force refresh; I still don’t see any tomato ratings. I’ll attach screenshots of my agents list incase i’m doing something wrong and someone can spot it!
#20
Remove the first entry “Rotten Tomatoes”. This is not an official Plex agent, since the RT rating has been implemented in the Freebase agent with the current release if I am not wrong. Remove it and try again.
