Safe to upgrade to 64bit version?
server-synology
#1
Quick question, my Synology model can now support 64bit PLEX (415+) and I have the 32 bit server running currently. Should I install the 64bit version when the next update comes out? Is it safe to install the 64 bit version over the 32 bit version?
Thanks!
#2
Your DS415+ has the Atom C2538 CPU which is a 64 bit processor and the same as my DS1815+. 64 bit mode works well (better than 32 bit too)
#3
Thanks! I saw from the sticky that I can use 64bit, but the question is can I upgrade without impacting my current library and settings. Thanks!
#4
Bit the bullet here and uninstalled my 32bit plex and loaded the 64bit install. Plex is working great on my 415+ and does in fact seem to run a bit faster! All my settings and library carried over from the 32 bit version into 64 bit.
Thank you plex team for the 64 bit version!
#5
Yes, Metadata and package binaries are stored in two different locations (in @appstore and the Plex share). You can uninstall the package and your metadata is still safe; until you delete the Plex share.
Simply install on top of. To downgrade, uninstall and re-install a lower version.
#6
where i get the 64-bit install spk?
#7
From downloads.plex.tv
