Samsung smart tv showing weird subtitle instead of arabic subtitle
samsung-smart-hub
#1
Samsung smart tv showing weird subtitle instead of arabic subtitle, but on my samsung
mobile s6 it's showing arabic subtitle, plz help
#2
Your subtitle is probably saved in the wrong encoding. Plex only supports UTF-8.
If it's a .srt file, open the subtitle in a texteditor that can set the encoding (like Notepad++).
Then change the file encoding to UTF-8 and save the file.
Place the file next to your movie and re-scan the library.
On the left hand side of the Preplay screen in the app, make sure that the correct subtitle is selected.
#3
Why PLEX not just support the Arabic encodes iso-8859, and windows 1256 ?
#4
see also https://forums.plex.tv/discussion/91444/arabic-subtitle-have-been-solved-finally/p1#top
#5
Because Plex supports many platforms and devices where these codepages simply don't exist.
There is a solution for all these character encoding issues, and that is to use a 16-bit character encoding, so switching codepages is no longer necessary.
And that is UTF-8.
#6
@OttoKerner
but on PLEX, I made that downloading subtitles automatically, and my server not in my home and there is a lot of stuff so that I can downloading them manually!
I hope in the near future PLEX will support the Arabic encodes.
#7
Have you tried https://forums.plex.tv/discussion/94864/rel-str2utf-8/p1#top
