Scan Library files - Not working on Ethernet
server-nvidia-shield
#1
Hello, scan library files is not working on built in Ethernet.
I have to switch to wifi !!!
I got this shield tv only yesterday and I have had nothing but troubleshooting for the past 24hrs !!!
WTF is going on ?? I thought this was supposed to be the ultimate plex server ?
Are you guys working with NVIDIA and GOOGLE fixing these bugs ?
#2
Logs attached
#3
Please explain what you mean by scan library files on built in Ethernet? Where is your media located (on the Shield TV's internal storage, on attached storage, on your local network)? How are you accessing the Plex Server settings?
#4
Hey sorry, just really annoyed that I have had to spend the last 24hrs trying to get this set up !
This is my 10th factory reset.
Network drive mounted from windows server 2012 R2 to Shield TV (Ethernet) (firewall off on win server for all domains)
Scan library finds no media (see logs attached)
Unplug Ethernet and connect to wifi, scan media is now working and files are added to my library.
It seems there is some smb issues when connected via Ethernet to my switch, if I connect via the wireless access point all works just fine.
Controlling plex server from pc with plex media player.
You can see in the logs of the plex server lots and lots of errors whils connected via Ethernet.
Kodi works just fine when on Ethernet and can scan / playback files on my windows media smb share.
#5
There are known issues with SMB + Shield TV + Plex. Lots of forum activity on the NVIDIA Shield TV board about it. I recommend you review all the threads on this forum, then head over to the NVIDIA forum and review those. There is an upcoming firmware update for the Shield TV that has been reported by beta users to fix it, so we've got that going for us, which is nice.
#6
I don't see how this can be a Nvidia issue, I can browse the mounted SMB folders on the NVidia shield with TV File Commander just fine and open the videos in VLC. Also no issues in Kodi browsing and scanning these mounted files.
Thanks for a wasted 2 days PLEX !!!!
#7
Total Commander and VLC are not Plex, so don't compare them. The Shield TV storage settings that allow SMB access are only there because of Plex, and Plex Server controls that. TC doesn't use it in any way, shape, or form.
#8
Ok great so now we have established the issue is a plex server issue :slight_smile:
And File Commander does and can access the smb that has been mounted on my system, so why not plex server ??*
Why all the errors in the plex logs ?
#9
Just did another reboot, plex server came back online as local host, had to claim it and now its scanning files on the SMB , fingers crossed !
Logs attached
#10
Your logs show that your TV library is pointing to the internal storage location.
May 08, 2017 16:08:19.242 [11317] DEBUG - Deleting directory
May 08, 2017 16:08:19.244 [11317] DEBUG - Deleting directory Android
May 08, 2017 16:08:19.246 [11317] DEBUG - Deleting directory Android/data
May 08, 2017 16:08:19.247 [11317] DEBUG - Deleting directory Android/data/com.android.vending
May 08, 2017 16:08:19.248 [11317] DEBUG - Deleting directory Android/data/com.android.vending/files
May 08, 2017 16:08:19.249 [11317] DEBUG - Deleting directory Android/data/com.google.android.music
May 08, 2017 16:08:19.250 [11317] DEBUG - Deleting directory Android/data/com.google.android.music/files
May 08, 2017 16:08:19.252 [11317] DEBUG - Deleting directory Android/data/com.google.android.youtube.tv
May 08, 2017 16:08:19.254 [11317] DEBUG - Deleting directory Android/data/com.google.android.youtube.tv/cache
May 08, 2017 16:08:19.255 [11317] DEBUG - Deleting directory Android/data/com.nvidia.tegrazone3
May 08, 2017 16:08:19.257 [11317] DEBUG - Deleting directory Android/data/com.nvidia.tegrazone3/files
May 08, 2017 16:08:19.259 [11317] DEBUG - Deleting directory Android/data/com.nvidia.tegrazone3/files/Download
May 08, 2017 16:08:19.260 [11317] DEBUG - Deleting directory Android/data/com.plexapp.mediaserver.smb
May 08, 2017 16:08:19.264 [11317] DEBUG - Deleting directory Android/data/com.plexapp.mediaserver.smb/cache
May 08, 2017 16:08:19.266 [11317] DEBUG - Deleting directory Android/data/org.xbmc.kodi
May 08, 2017 16:08:19.267 [11317] DEBUG - Deleting directory Android/data/org.xbmc.kodi/files
May 08, 2017 16:08:19.269 [11317] DEBUG - Deleting directory Android/obb
May 08, 2017 16:08:19.271 [11317] DEBUG - Deleting directory Android/obb/org.xbmc.kodi
Did you intend to have these folders in your library?
#11
If you check the logs again you will see that I'm pointed to the smb
/storage/STORAGE/Movies/
/storage/STORAGE/Tv/
