SD Card Sync on Amazon Fire HD 8
android-mobile
#1
No matter what order I install the SD card in, whether I move the Plex app to tablet or SD card, whether I format the SD card, etc., the storage from the SD card does not appear in the Plex application. Is there a magic trick that I'm missing?
#2
Hi, did you find a solution for this issue. Today I just started with Plex and I´m also playing around with the fire hd8 from my kids. I also do not see the possiblity to select the sd card to synchronize movies to the sd card.
best regards
-slaYer977-
